#340428 - 18/12/2010 04:51 Audio stuttering with new disk
I've just replaced the nGB disk (where n < 60) in my empeg with a 160GB Samsung disk. I used the big disk builder, and I've loaded v3a11+hijack, and all of the capacity is visible to emplode. I've loaded about a third of my music onto it, and am just about to load the rest this morning. I have about 40GB of music.
I took the empeg out for a test in the car yesterday, and the audio is stuttering a little. It might be hard-disk-spin-up-related, but the hard disk indicator is not always on when it happens, and it tends to be very small glitches of 0.1 second or so.
I'm going to get a serial capture at some point today, but is anyone currently aware of similar problems with "large" hard disks and stuttering?
#340431 - 18/12/2010 12:28 Re: Audio stuttering with new disk [Re: Roger]
New notebook drives often have various levels of "power saving" set ON by default. You might be able to check for that with "hdparm -B /dev/sda", and modify it (OFF) with "hdparm -B255 /dev/sda"
#340441 - 18/12/2010 16:09 Re: Audio stuttering with new disk [Re: mlord]
Good tip. I'll try that later this evening.
#340448 - 19/12/2010 09:18 Re: Audio stuttering with new disk [Re: Roger]
hdparm v9.8 doesn't query the power saving setting with hdparm -B /dev/hda; it reports:
empeg:/drive0/bin# ./hdparm -V
hdparm v9.8
empeg:/drive0/bin# ./hdparm -B /dev/hda
  -B: bad/missing power-management-mode value (1..255)
It appears that it's disabled anyway ("AdvancedPM=yes: disabled (255)"):
empeg:/drive0/bin# ./hdparm -i /dev/hda
/dev/hda:
 Model=SAMSUNG HM160HC, FwRev=LQ100-10, SerialNo=S12TJDQZ936826
 Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs }
 RawCHS=16383/16/63, TrkSize=34902, SectSize=554, ECCbytes=4
 BuffType=DualPortCache, BuffSize=8192kB, MaxMultSect=16, MultSect=16
 CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=312581808
 IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120}
 PIO modes:  pio0 pio1 pio2 pio3 pio4
 DMA modes:  mdma0 mdma1 *mdma2
 UDMA modes: udma0 udma1 udma2 udma3 udma4 udma5
 AdvancedPM=yes: disabled (255) WriteCache=enabled
 Drive conforms to: ATA/ATAPI-7 T13 1532D revision 0:  ATA/ATAPI-1,2,3,4,5,6,7
 * signifies the current active mode
I'll leave it playing and capture a serial trace...
#340449 - 19/12/2010 09:20 Re: Audio stuttering with new disk [Re: Roger]
I've not bothered with set_max_fid or any other bigdisk-related changes, because I don't have much music loaded.
#340453 - 19/12/2010 16:12 Re: Audio stuttering with new disk [Re: Roger]
Any chance it's just a glitch in the alpha?
#340462 - 20/12/2010 07:13 Re: Audio stuttering with new disk [Re: tfabris]
Hah. Just this morning, I was thinking: "how long until Tony blames it on the alpha?"
Not unless it's got a problem with bigger disks. I've been running the alpha for the last 5 years with no glitching problems.
I suppose, worst case, I could just burn some of the space as unused.
Edited by Roger (20/12/2010 13:08)
Edit Reason: get a quick dig in at Tony
#340474 - 21/12/2010 05:03 Re: Audio stuttering with new disk [Re: Roger]
grin
#340604 - 27/12/2010 14:54 Re: Audio stuttering with new disk [Re: Roger]
peakmop
Loc: 384400 km from the Moon
I've had similar problem while running v3a11 player with newly encoded MP3 tracks. However the problem seem to go away after re-flashing to v2 and then back to v3a11.
