#343938 - 01/04/2011 01:45 setting audio channels on the mk2
thirdeyevision
Loc: Petaluma, CA (Bay Area)
i am having trouble changing the channel setting on the empeg. i am currently in the 2 channel mode and would like to switch it to 4 channel mode. i have a couple other empegs but they all were set in 4 channel mode when i received them.
how do i go about this?
#344036 - 04/04/2011 17:12 Re: setting audio channels on the mk2 [Re: thirdeyevision]
The equalizer only gives you four channel mode as an available option when it think's it's plugged into a car docking sled. Without the car docking sled, there aren't four outputs connected, so, no four channel mode. List of things that the player does differently between home and car mode.
The option to switch between four and two channel mode is somewhere in the equalizer presets screen. It's been a while since I've been in there, so dig for it.
If your player is in the car docking sled but doesn't give you the 2ch/4ch option, it might be having this problem.
#344039 - 04/04/2011 18:15 Re: setting audio channels on the mk2 [Re: tfabris]
Isn't it also possible to force one mode or the other in Hijack?
#344077 - 06/04/2011 14:50 Re: setting audio channels on the mk2 [Re: Robotic]
I mention that in the second link. Perhaps I should add it to the first link.
#344080 - 06/04/2011 15:37 Re: setting audio channels on the mk2 [Re: tfabris]
Ah- of course. Sorry.
Let me take this opportunity to show my appreciation of the FAQ, Tony.
The document is above and beyond anything I've ever encountered before. It's truly a marvel! The FAQ and this bbs are strong selling points for empeggers-to-be.
Thank you for all of your efforts!
#344083 - 06/04/2011 16:55 Re: setting audio channels on the mk2 [Re: Robotic]
Mention of that feature now exists in both of those links. Thanks!
