#346996 - 19/08/2011 10:11 no harddisk found - repair in Holland/Europe?
juenk
Loc: Waardenburg, The Netherlands
I think my empeg has problems with soldering of the IDE connector. If I open the empeg, and have the disk & mounting plate taken out (cables still connected), the empeg boots up usually OK. When I place all back into the case and fix all screws again, it sometimes works OK, sometimes not. When opened, and pressing here or there on the motherboard, it works sometimes OK as well.
To me this seems like a problem with soldering of the IDE connector, although visual inspection did not show a clear issue here.
Any suggestions how to get this fixed? I can't solder such things myself...
Jelle
Empeg M2A Blue # 010101908 80Gb
Empeg M2A Blue # 030102771 with backlight buttons - Need repair (IDE cable connection on main board) - volunteers?
#347019 - 20/08/2011 08:55 Re: no harddisk found - repair in Holland/Europe? [Re: juenk]
Could be the soldering of the header OR the crimp on the cable.
http://www.riocar.org/modules.php?op=mod...;faqent=221#221
Any decent electronics tech (TV etc) could resolder the header. I think Eutronix above can supply replacement IDE cables.
Edited by Shonky (20/08/2011 08:55)
#347020 - 20/08/2011 08:58 Re: no harddisk found - repair in Holland/Europe? [Re: Shonky]
Maybe also post a boot log of working and not working but from the info you've provided it sounds like the cable or the header.
http://www.riocar.org/modules.php?op=mod...mp;faqent=82#82
#347047 - 22/08/2011 05:45 Re: no harddisk found - repair in Holland/Europe? [Re: Shonky]
juenk
I already got a replacement cable from Eutronics few years back, don't know though whether I placed it in this empeg or my spare (now dead) one....
Jelle
