#348627 - 31/10/2011 01:01 Skype
My sister has moved to Italy and I need a grandma proof Skype to Skype only solution.
My Requirements:
1) Always on, pc-free as far as actual use goes.
2) As easy to use as a phone or cell-phonebook function.
3) It needs to be something I can setup and forget. That part need not be PC-free.
At the moment I'm looking at the Freetalk adapter.
#348634 - 31/10/2011 05:45 Re: Skype [Re: gbeer]
iPad or iPod Touch ?
#348647 - 31/10/2011 12:43 Re: Skype [Re: gbeer]
Lucky git!
.. and I need a grandma proof Skype to Skype only solution.
If using a wired handset (or cordless DECT telephone) is an option, then the most grandma-proof setup is probably an ATA plugged into her internet router, with the handset plugged into that. Then it will work just like a landline from her point of view.
I suggest you acquire and configure a suitable ATA and then send it to her fully set-up -- plug and talk at her end.
"ATA" = "Analog Telephone Adaptor" (eg. Linksys PAP2T series, etc..).
This will also require a voip service provider (unless you can find a Skype-locked ATA), but voip service is incredibly cheap ($2-5 monthly, or even a free service) so that shouldn't be an issue.
#348649 - 31/10/2011 13:22 Re: Skype [Re: andy]
facetime really is quite good, and very easy to use. If she can use a mobile phone she can use facetime.
#348652 - 31/10/2011 14:06 Re: Skype [Re: Cris]
I second Facetime. Works on a cheap[ish] iPod touch. Also has the advantage that it requires much less bandwidth and works better over high latency connections than Skype does. I use it all the time over my satellite internet when Skype can't even maintain a good connection. I use the mac version on a MBP.
#348654 - 31/10/2011 14:18 Re: Skype [Re: JBjorgen]
Given what's in the link Glenn posted, I think he might be looking for something strictly for voice calls. Mark's ATA suggestion is the most straight-forward and bullet-proof, IMO.
Once it's set up "here" you just need an internet connection anywhere in the world to plug it in and go.
#348656 - 31/10/2011 15:56 Re: Skype [Re: hybrid8]
Voice calls. How quaint.
#348668 - 01/11/2011 02:23 Re: Skype [Re: gbeer]
Okay, that looks like an ATA locked to Skype service. Should be pretty simple to set up and operate, then.
#348705 - 02/11/2011 00:37 Re: Skype [Re: mlord]
The Skype preference is coming from the sister. Her, the b.i.l. and the daughter are already setup with Skype.
#348706 - 02/11/2011 00:49 Re: Skype [Re: mlord]
Lucky git!
smile heh,heh, I can read that as, lucky me, or lucky her.
#348708 - 02/11/2011 01:14 Re: Skype [Re: gbeer]
I believe the Freetalk is how I'll go. If there were more contacts than than just Sis, I'd look for a handset with an LCD and a phone book.
The next problem is purely mechanical. Routing new wires. I do so dislike crawling around in loose fiberglass insulation. A pox on Owens-Corning.
Wired to keep the number of failure points down.
