#351729 - 21/04/2012 17:50 help me identify what I found in my oil pan :)
Not satisfied with the answers I'm getting on Jeepforum. Check the pics in the thread. The plastic piece is just one piece, I just tried to get pics from different angles. It's about 2" x 1" square, but it likely broke off something larger.
Jeep Wrangler 4.0l inline six.
Thread here:
http://www.jeepforum.com/forum/f12/help-me-identify-what-i-found-my-oil-pan-pics-1359139/
any ideas?
#351731 - 21/04/2012 21:03 Re: help me identify what I found in my oil pan :) [Re: JBjorgen]
It seems weird that there would be something plastic in the engine that could get into the oil pan. Was there anything in the oil filter?
Edited by msaeger (21/04/2012 21:04)
#351732 - 21/04/2012 21:09 Re: help me identify what I found in my oil pan :) [Re: msaeger]
People on forums for other kinds of cars are guessing timing chain guide too but would that have a set screw in it?
#351733 - 21/04/2012 21:18 Re: help me identify what I found in my oil pan :) [Re: JBjorgen]
Ball plunger. Used to produce a detent action on a sliding part. Refined versions hold sockets on ratchet wrenches.
If you still have the last oil filter, you might autopsy it for more bits of junk.
Do you have a pic to confirm how the screw fits agains the plastic bit?
#351734 - 21/04/2012 21:27 Re: help me identify what I found in my oil pan :) [Re: gbeer]
#351735 - 21/04/2012 21:37 Re: help me identify what I found in my oil pan :) [Re: gbeer]
Click thru on item 40 - could that have been the part?
#351736 - 22/04/2012 01:03 Re: help me identify what I found in my oil pan :) [Re: gbeer]
That's the only thing I can fathom it being also. The piece I have clearly has some grooves in it that aren't in the pictured one, but that could be simply the OEM vs. aftermarket thing.
I also can't see in the pictures where the ball plunger screws in, and there's a place on mine for it. You can kinda see it in the lower right picture. A hole on the upper right edge where the ball plunger screws in diagonally. I'll get a picture of the plunger partially screwed in when I get back to the village. (I'm in the city for shopping now).
#351737 - 22/04/2012 13:04 Re: help me identify what I found in my oil pan :) [Re: JBjorgen]
those ball things are also used to hold the thumbwheel in on adjustable wrenches.
#351746 - 23/04/2012 11:56 Re: help me identify what I found in my oil pan :) [Re: JBjorgen]
It's also possible that someone that worked on the car broke a tool and the pieces ended up in the oil pan.
#351747 - 23/04/2012 12:12 Re: help me identify what I found in my oil pan :) [Re: gbeer]
We shot a transmission with a good sized round while it was running, and had it continue running for 30mins afterwards. It didn't have as much debris as that timing chain when we pulled it apart.
#351794 - 25/04/2012 22:26 Re: help me identify what I found in my oil pan :) [Re: Tim]
Thanks guys. I ordered a new timing chain and guide since it's about time to swap it out anyway. We'll see what it looks like.
One thing that cushions the blow a bit is that I'll likely pay about $50 in labor to get it swapped. There are some benefits to living in the majority world smile .
#351808 - 26/04/2012 10:54 Re: help me identify what I found in my oil pan :) [Re: JBjorgen]
While you’re in there you might consider putting in a hotter cam if you’d like a bit more performance. Make sure to get new lifters too.
