#351964 - 03/05/2012 11:51 Bizarre C-Shell Script Problem
This is just baffling. As part of a software installation package, I have a series of C-Shell scripts. The main script calls the rest.
The issue I am having is that the main script isn't calling the embedded one. The call looks like this:
if (-e ${media}/bin/check_os) then
        echo "${media}/bin/check_os exists.  Calling check_os"
        echo "Outside check_os.  Status is $(status)"
        if ($status == 1) then
                echo "check_os status = 1"
                goto fatal-fixable-exit
The variable media is defined correctly and the echo before the call looks good. Then, inside the check_os script, I have an echo right after #!/bin/csh that never gets called, so the status variable never gets set. Running the command /media/dvd/bin/check_os ($media is /media/dvd in the above script) from the prompt works fine.
I've never seen this problem before, and it has worked on several machines previously. Anybody have a clue what is hosed up?
#351965 - 03/05/2012 12:42 Re: Bizarre C-Shell Script Problem [Re: Tim]
Well, there's your problem.
wink
Does /bin/csh exist? Some systems will only have a /usr/bin/csh. If it doesn't exist, then change your '#!/bin/csh' line in the new script.
#351966 - 03/05/2012 12:51 Re: Bizarre C-Shell Script Problem [Re: wfaulk]
It does. Since this has worked a zillion times previously, albiet on clean OS installs, I'm at the point where I just back up the machine and nuke the site from orbit. It's the only way to be sure.
#351967 - 03/05/2012 12:53 Re: Bizarre C-Shell Script Problem [Re: Tim]
Then run it via strace and see where it's going wrong.
#351968 - 03/05/2012 15:01 Re: Bizarre C-Shell Script Problem [Re: Tim]
So the only other explanation is that the second script is not in the search $PATH provided in the first script.
Except you've hardcoded the path.
Ugh. /bin/sh anyone?
Edited by mlord (03/05/2012 15:01)
#351969 - 03/05/2012 15:04 Re: Bizarre C-Shell Script Problem [Re: Tim]
I gave up on csh decades ago: remind me again how "status" gets set?
As the result of executing a command?
Like the "echo" command on the line before the status check? wink
#351970 - 03/05/2012 15:10 Re: Bizarre C-Shell Script Problem [Re: mlord]
Stick a "set -x" line at the top of each script, just after the "#!" lines. This will enable line-by-line tracing of execution.
#351972 - 03/05/2012 16:35 Re: Bizarre C-Shell Script Problem [Re: mlord]
I'm not sure what the issue was, after dorking around with it for a few hours I thought it would be quicker to just start from scratch. I reinstalled the base system it was expecting (RedHat 5.5, but I use CentOS) and it magically started making the calls again.
The only thing I can figure is that since this was a machine I was using for other purposes, I was keeping it updated. One of the patches since that release and now must have mucked with something that the script was using.
Like I said, completely bizarre. Thanks for the suggestions on strace (which I completely forgot about) and set -x (which I never even knew about).
