#355153 - 27/09/2012 05:05 What is this thing on the ceiling of my garage?
It's not near the garage door opener or the furnace or the hot water heater. Looks like some kind of a dc transformer. The living area above it has nothing special there, just bedrooms with no special equipment.
(Hopefully the photo successfully attached, I'm doing this from my phone. )
Description: What is this thing on my garage ceiling?
#355154 - 27/09/2012 05:15 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
julf
How close are you to the Russian embassy? smile
The wiring looks low voltage, could it be a temperature sensor or the remains of some old alarm system?
#355155 - 27/09/2012 05:26 Re: What is this thing on the ceiling of my garage? [Re: julf]
House is brand new construction, not a single thing in the house is a remnant of anything. Every plug and switch and appliance in the house works, and is connected to something.
If it is alarm system related, it would be for the currently installed and working alarm system that was built in to the house. If so: what part is that, and what purpose does it serve?
#355156 - 27/09/2012 06:22 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
adavidw
Loc: Utah, USA
Doorbell transformer?
I don't know why it would be in that location, though...
-Aaron
#355157 - 27/09/2012 06:36 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
julf
So it is in the ceiling, with the back side facing up into the isolation space between the ceiling and the floor of the bedroom? And only a 2-pole, thin cable? Trying to see from the pic - is it a normal 2-pole cable, or a coax/mic cable (one normal centre conductor, and one metal shield twisted into a conductor)?
#355158 - 27/09/2012 06:52 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
What size is it? It looks kinda small, but it's hard to tell.
#355159 - 27/09/2012 08:14 Re: What is this thing on the ceiling of my garage? [Re: Roger]
Looks like an AC transformer plugged into a GPO.
Very dodgy for a new house in terms of the hole in the roof.
Get up in the ceiling and follow the wire?
#355162 - 27/09/2012 10:21 Re: What is this thing on the ceiling of my garage? [Re: Shonky]
I'm going to vote doorbell transformer too.
#355163 - 27/09/2012 10:59 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
Maybe a remote phone ringer?
If you don't have a house phone that is probably why it never rang.
#355164 - 27/09/2012 11:21 Re: What is this thing on the ceiling of my garage? [Re: Redrum]
AC transformer... do you have a sprinkler control in the garage?
#355165 - 27/09/2012 12:47 Re: What is this thing on the ceiling of my garage? [Re: larry818]
Around here, the typical place for a doorbell transformer is near/at the electrical panel. This does look like a doorbell transformer, but I'm wondering why it would be connected to a single gang work box in the ceiling. Away from anything else. And presumably with the wire routed to/via a sub-optimal location to actually get to the doorbell, which is probably not upstairs.
No matter what it is, I think the installation is a little odd. Is your electrical panel in the garage Tony?
#355167 - 27/09/2012 13:04 Re: What is this thing on the ceiling of my garage? [Re: hybrid8]
Well, you could always try disconnecting it and see what breaks. If it's just for the doorbell, then it's easy enough to test. You might also want to get up there with a voltmeter to see whether you're likely to kill yourself or not monkeying with those wires.
#355168 - 27/09/2012 13:18 Re: What is this thing on the ceiling of my garage? [Re: DWallach]
Just knock it down with a shovel or broomstick. wink
#355171 - 27/09/2012 13:49 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
99% likely it's a 24VAC (output) "doorbell" style of transformer, getting 120VAC input from the light socket that it directly covers.
This could be for doorbell use, or for the automatic garage door opener, or any other (?) low voltage household needs. Heating and cooling equipment also use 24VAC for control wires (thermostats) and the like. Or a furnace humidifier, central vac control wires, ..
#355173 - 27/09/2012 14:05 Re: What is this thing on the ceiling of my garage? [Re: mlord]
I agree that the location is a little odd, but, the electrical panel is located on the outer wall of the garage, so this object's location does put it half way between the front door and the electrical panel. Although the doorbell doesn't ring in the garage, it rings in the house.
Is it normal to put the transformer so far away from the doorbell itself?
#355177 - 27/09/2012 14:18 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
My doorbell transformers have always been fairly far from the doorbell itself. The electrical panel is in the basement and the doorbell on the main level in the center of the house or close to the front door. It means a longer run of low-voltage 2 conductor cable (little copper) versus a longer run of mains voltage wire (3 conductors, 14ga, a lot more copper).
The central vac thing makes some sense too. The wire would be used for the switching and accessory power. But it still seems like an odd location/placement.
I've never seen a low-voltage garage door opener - and again the placement and wire run for this would be really odd.
#355182 - 27/09/2012 14:50 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
Given that it's brand new, why not just call up the builder, and ask?
#355186 - 27/09/2012 15:07 Re: What is this thing on the ceiling of my garage? [Re: canuckInOR]
What fun would that be smile
#355187 - 27/09/2012 15:43 Re: What is this thing on the ceiling of my garage? [Re: msaeger]
Preposterous.
#355196 - 27/09/2012 18:44 Re: What is this thing on the ceiling of my garage? [Re: msaeger]
I Tony really cared about having fun with figuring out what that thing is, he'd be writing a Filk song about it. wink
#355209 - 28/09/2012 06:43 Re: What is this thing on the ceiling of my garage? [Re: mlord]
julf
Ah, yes, that would make sense!
#355235 - 28/09/2012 16:42 Re: What is this thing on the ceiling of my garage? [Re: julf]
RobotCaleb
I have an outlet similar to this in my attic next to my furnace. I verified that it's not the doorbell when I was last up there. My guess for mine is alarm system stuff or thermostat stuff. I didn't bother tracing the wire around the attic to see if it ended up in the furnace.
#355248 - 28/09/2012 21:54 Re: What is this thing on the ceiling of my garage? [Re: tfabris]
Not likely installed at time of construction. I'd go with 24vac xfmr. for doorbells, thermostats, smoke detectors, water heater control, sprinkler system.
I'll bet on sprinkler system. It's the kind of thing a homeowner will do after the home is occupied.
#355283 - 01/10/2012 14:52 Re: What is this thing on the ceiling of my garage? [Re: gbeer]
Newer construction around here (Portland) tends to come with a sprinkler system already installed. Ours did.
