#356906 - 22/12/2012 14:27 1mm thick styro foam panels
Guys, I am having a hard time finding them. Do you know any shop on line in EU?
They don't have to be big. I am using it to mount a tweeter in a self-made speaker, so I will of course have to cut it as needed, but can't be thicker than 1mm.
Thank you!
#356907 - 22/12/2012 15:27 Re: 1mm thick styro foam panels [Re: Taym]
1mm styrofoam? Surely that wouldn't hold a tweeter, or anything much. If you want 1mm solid polystyrene, that's easier to find.
#356908 - 22/12/2012 16:41 Re: 1mm thick styro foam panels [Re: peter]
Go to your butcher shop in the local grocery store. The trays the meat is sold in should work. They'll most likely give you one.
A do it your self'r will breakout the hot wire and slice off the needed piece.
#356909 - 22/12/2012 20:09 Re: 1mm thick styro foam panels [Re: gbeer]
#356910 - 23/12/2012 08:17 Re: 1mm thick styro foam panels [Re: gbeer]
Thank you.
I need 1.0mm because it will just serve as thin layer between tweeter and wooden case, so sorry for not being clear. Your recommendation above do help!
I found this at modelshop.co.uk, which is what I was looking for: http://www.modelshop.co.uk/styrofoam-blue-1-x-330-x-580mm-4718-p.asp smile
Edited by Taym (23/12/2012 08:20)
