#358298 - 16/04/2013 11:41 VPN Software
I'd like to connect my laptop(s) to my home network using some sort of VPN solution, and I thought I'd turn to the BBS for guidance.
I've got a bunch of mobile devices (Windows 8 Pro Laptop, Windows 7 Ultimate Laptop, Linux laptop (maybe), Samsung Galaxy S3, Nexus 7) that I'd like to connect to my home network. In terms of places to implement a VPN, I've got a router running OpenWRT; a Windows Server 2012 server (physical); an Ubuntu server (virtualized).
I've got a single fixed IPv4 address, and a fixed IPv6 /64 address range. (Using the IPv6 would probably require some sort of 6to4 tunnel when I'm at work).
If it makes it easier, I'm only really bothered about the Windows 8 laptop. The others are nice-to-have or merely frivolous.
What's my best option for a VPN? Windows supports a bunch of different variations (probably with MS-specific tweaks), and the OpenWRT wiki can't seem to decide between IPSec, OpenVPN or PPTP (and the documentation's terrible for all of them).
#358303 - 16/04/2013 20:18 Re: VPN Software [Re: Roger]
I use openvpn. You can almost certainly do anything you need with it and it's less likely to hit firewall tunneling issues than IPSec. I have no clue about windows clients but there are bound to be some.
Technically optimum is to use UDP but some hotel wifi will block it so I run it on TCP port 443 for maximum accesibility.
#358320 - 17/04/2013 21:04 Re: VPN Software [Re: LittleBlueThing]
PPTP is dead simple to configure/use.
And similarly easy to crack in most setups.
OpenVPN is way more complex to set up, but simple to use after the initial pain.
#358325 - 18/04/2013 06:43 Re: VPN Software [Re: mlord]
Reawn
Astrill is a great vpn i have used.
