#359643 - 09/09/2013 00:45 Display Board Technical Drawings?
Joe Gorman
Loc: Oak Hill, WV, USA
I'm making a custom faceplate out of acrylic for my empeg to make it look like a classic radio for my Datsun 510 (bakelite knobs with chrome inlays, etc)
In order to get the design right, I need accurate (better than I can get with a camera) locations of the screw holes, two-function button/knob, screen, and IR sensor.
Does anyone have either technical drawings of the display board, or know where I can get them? I have AutoCad, Sketchup, GIMP, and Adobe software.
-joe
Description: Inspiration
#359646 - 09/09/2013 11:16 Re: Display Board Technical Drawings? [Re: Joe Gorman]
These may provide a decent starting point.
The scans were done at 300x300dpi, so each pixel in the images represents exactly 1/300th of an inch.
(Edit: fixed orientation and naming of original uploads)
Description: Front of empeg Mk2 display board.
Description: Rear of empeg Mk2 display board.
#359648 - 09/09/2013 15:16 Re: Display Board Technical Drawings? [Re: mlord]
One could also try scanning the backside of the fascia on a flatbed scanner, in the same fashion.
#359651 - 09/09/2013 17:56 Re: Display Board Technical Drawings? [Re: tfabris]
mtempsch
I'm fairly sure there should be pictures of that around somewhere from back when 303, IIRC, did the aluminum fascias and knobs. Haven't been able to find them (but haven't been digging very hard or long)
#359653 - 09/09/2013 20:38 Re: Display Board Technical Drawings? [Re: tfabris]
Description: Backside of fascia, 300x300dpi.
#359679 - 12/09/2013 20:03 Re: Display Board Technical Drawings? [Re: Joe Gorman]
Attached is a 2D DXF file of the top and bottom layers of the last version of the Mk2A display board. It should be exactly 1 to 1.
issue 9R2 empeg display board 2d.dxf (412 downloads)
#359680 - 12/09/2013 20:09 Re: Display Board Technical Drawings? [Re: Joe Gorman]
Here's one with the silk screens, which will be more useful.
issue 9R2 empeg display board 2d with silks.dxf (420 downloads)
