#361483 - 26/04/2014 11:45
Need help troubleshooting Bluetooth A2DP delay problem.
All,
I need help with a Bluetooth A2DP delay problem with my CR-V. Unfortunately, Honda outright refuses to even start to troubleshoot it. So, I thought this would be the best place to turn to next.
I've got a 2014 CR-V LX AWD without Nav and a T-Mobile Samsung Galaxy S4 running KitKat. (FWIW, I can repro with my son's iPod and my Win8 laptop.) The issue is that all audio streamed over A2DP is played on a full 3 second delay. Annoying enough for playing music, it makes it useless if my kids want to play a game or watch a video.
I've got a BT HCI snoop log if that helps. I opened it in Wireshark but don't know what to look for.
Does anyone have any suggestions for what to do next?
Thanks, Ruben
Edited by rubennyc (26/04/2014 13:12)
#361484 - 26/04/2014 11:57
Re: Need help troubleshooting Bluetooth A2DP delay problem.
[Re: rubennyc]
... I can repro with my son's iPod and my Win8 laptop... Each playing through the Honda? Does the phone have proper Bluetooth audio without delay when working through other cars?
#361485 - 26/04/2014 12:41
[Re: K447]
Hi, this is the only BT device where I've ever seen this kind of delay. My phone has no delay at all with my Plantronics headset or any non-Honda car (e.g. Nissan, Toyota, Mercedes, etc.) I've tested.
Edit: Attaching bt snoop logs from my phone: One is for my care with the delay, and one is for my Plantronics Marque 2 headset with no delay as a reference.
btsnoop_hci_crv_delayed.log (381 downloads)btsnoop_hci_Plantronics_good.log (325 downloads)
Edited by rubennyc (26/04/2014 13:15)
#361486 - 26/04/2014 14:05
[Re: rubennyc]
Does the iPod play properly through the Honda?
#361487 - 26/04/2014 14:08
[Re: rubennyc]
Over Bluetooth the iPod and my laptop have the same exact delay, but only in the Honda, not anywhere else.
#361488 - 26/04/2014 14:47
[Re: rubennyc]
Over Bluetooth the iPod and my laptop have the same exact delay, but only in the Honda, not anywhere else. Perhaps you can test this at the dealer in another 2014 Honda with the same radio. If it also fails there, it is a Honda warranty problem, no?
#361490 - 26/04/2014 19:43
[Re: rubennyc]
Does it misbehave when you're making a phone call? A three second latency for music is annoying. For phone calls, it's unusable. That might be your angle to fix this.
(Analogy: back in the day if your phone line had crappy audio quality and it rendered modems unusable, you'd complain that your fax machine wouldn't work, otherwise they'd laugh at you.)
#361491 - 26/04/2014 19:52
[Re: rubennyc]
DWallach, not a bad thought, but the telephone (handsfree) profile works fine. Better still, if I start playing music while on a phone call, there is no delay but the sound quality is garbage.
#361495 - 26/04/2014 22:02
[Re: rubennyc]
A2DP allows for microphone interaction, right? I'll bet something like Skype will use A2DP rather than the handset profile and would then trigger the bug.
#361496 - 26/04/2014 22:11
[Re: rubennyc]
A2DP is just for streaming audio like music. The headset profile is used for phone calls and things like Skype. So, oddly enough, Skype works great.
#361501 - 27/04/2014 06:35
[Re: rubennyc]
A2DP is one way for audio i.e. a music player. A delay shouldn't be a problem, but it would certainly frustrate me.
#361503 - 27/04/2014 10:26
[Re: Shonky]
A delay shouldn't be a problem, but it would certainly frustrate me. It's a problem if, as he said, someone is trying to watch video on the device with the audio going through bluetooth, and the audio is delayed 3 seconds. That would be unusable. Unfortunately I'm not sure what the issue is. It's clearly a problem with the car, and I think you've done your proper diagnostic steps. Have you joined any CRV owners forums?
#361504 - 27/04/2014 12:56
[Re: rubennyc]
CR-V forums haven't been helpful so far. All the docs I've read say A2DP latency can be upwards of 120ms. I'm completely ok with that. But 3000ms is inexcusable.
#361505 - 27/04/2014 15:29
[Re: rubennyc]
#361508 - 27/04/2014 17:16
I've had the singularity occur where, I google search to find out the solution to a technical problem, and I find the answer here on the EmpegBBS... with the solution having been posted by me.  That's exactly why I turned here.  For some reason Honda keeps calling it "Normal Operation". When I took it to Consumer Relations, they even went so far as to call it a "Feature." It took all my willpower not to say, "You keep using that word; I do not think it means what you think it means."
Edited by rubennyc (27/04/2014 17:18)
#361509 - 27/04/2014 23:04
[Re: rubennyc]
Yeah, that last one is me. Of course it is! (I love this board for the expertise and favorable signal to noise ratio. I wish I had more to offer the community, but most of y'all are way beyond me. Still, I check in most every day.) -jk
#361590 - 07/05/2014 13:43
[Re: rubennyc]
FWIW I think I've found the bug in Honda's code. When the Honda sends a "Service Search Attribute Request" for the "Audio Source" service on my phone it's omitting the UUID. The UUID is required. As a result, my phone responds with "Unknown service" and ends up transmitting all audio as generic data.
With the other devices I've tested, the UUID is there, my phone responds with the required information for the Audio Service, and all music gets streamed using RTP (Real Time Protocol).
On phone with Honda now.
#361591 - 07/05/2014 15:44
[Re: rubennyc]
Curious to know if you get anywhere with that, and if so, what the hoops were that you had to jump through. These days, reporting a bug to a software company is usually just opening a ticket with their tech support by phone or by webform. But I have no idea what that path would be with a car company. With vehicle subsystems becoming increasingly dependent upon software, I wonder if car companies are figuring out ways to open those channels somehow, and if so, how they're doing it. Nice catch, by the way.
#361592 - 07/05/2014 16:21
[Re: rubennyc]
Tony, I'm still trying to figure out how Honda is organized. In this case, I got nowhere with their "In Car Technology Support" line. Apparently there's a separate "Honda Technology Department", and that's who I spoke to today. They even gave me an email address and a case number so I could send them my traces, screenshots, and novice analysis.
/fingers crossed.
#361593 - 07/05/2014 17:38
[Re: rubennyc]
Wow. You'd think the former would have been the correct one.
#361596 - 08/05/2014 08:29
[Re: rubennyc]
Great piece of debugging Ruben, I'm also interested to see how far you will get in trying to get that fixed.
Just to note that iirc the integrated navigation, radio, and bluetooth 'system' in my old 2006 Honda Civic FK3 was all made by Alpine (who actually seem to make a lot of OEM stuff).
#361601 - 08/05/2014 18:24
[Re: rubennyc]
Thanks guys. Not sure how far I'll get either. Yesterday I made the argument that, if I'm right (which is far from certain), that would mean the Honda Bluetooth for Audio is incompatible with every phone on the market.  I expect it's going to be a while before anything happens. At this point I'd feel much better just to hear them say, Yes, it's a bug, we're going to fix it. I'll keep you posted.
#361627 - 09/05/2014 23:05
[Re: rubennyc]
I've forwarded a link to this thread to a Google Android insider. Dunno if/when they can engineer a workaround, and whether or not that will help you with your Samsung phone, but I'd put my money on Google doing a workaround before I'd put my money on Honda doing a bug fix.
#361631 - 10/05/2014 15:41
[Re: DWallach]
I've forwarded a link to this thread to a Google Android insider. Dunno if/when they can engineer a workaround, and whether or not that will help you with your Samsung phone, but I'd put my money on Google doing a workaround before I'd put my money on Honda doing a bug fix. I really appreciate that. Right now, I'm anxious to find out if the missing UUID really is the likely cause or something else. For all I know it could be a search string syntax issue, e.g. none of the working traces use colons ":" in the search string. In the interest of completeness, I'm attaching 3 new traces. These traces include the initial pairing process through to audio playback. One trace is for the Honda, the other two are for a Plantronics bluetooth headset and a Mercedes Benz OEM head unit. Only the Honda has the delay. Thanks again, Ruben
btsnoop_hci_Honda_3sec_audio_delay.log (345 downloads)btsnoop_hci_Mercedes_no_audio_delay.log (306 downloads)btsnoop_hci_plantronics.log (304 downloads)
#361639 - 12/05/2014 02:35
[Re: rubennyc]
Dan, while you're at it, you should tell them that the AVRCP profile for Android is awful. I have this in-car bluetooth device, and while I've been impressed with the reliability of its A2DP pairing (pretty good so far), the AVRCP profile has been absurdly frustrating. Half of the time I get in my car, when I try tapping the button to play back audio, I can't start up whatever was playing the last time I played audio (usually my podcatcher). Normally, I'd chalk this up to issues like the app has been in the background too long and was closed, or the system can't assume what the last audio being played was. The real frustration is when I'm currently playing audio, and tapping the button doesn't pause playback. That's just broken. About half of the time, if I press the main button on that device or try using the forward and back buttons, nothing at all happens. I bought this thing so I could keep my eyes on the road and still skip through audio, but Android is screwing it up. I'm not blaming the device because I've always had bluetooth issues with Android, especially when it comes to AVRCP.
#361644 - 12/05/2014 07:00
Matt, Thank you, thank you, thank you for bringing this device to my attention. I was looking for something like this for a while now. Well, not actively looking, but thinking "something like this must surely exist?". The only things I could come up with so far were battery powered, and I don't want those. This device seems to fit the bill perfectly. I'm using an iPhone, so hopefully that AVRCP issue you're mentioning won't bother me as much. Edit: bought one on Amazon.
Edited by Archeon (12/05/2014 07:53)
