#362347 - 08/08/2014 13:13 Foil milk bottle tops?
Simple question:
I've got some glass milk bottles; I'd like to fill them and then seal them with foil tops, such as Unigate Dairy would have used back in the day.
How?
#362348 - 08/08/2014 13:48 Re: Foil milk bottle tops? [Re: Roger]
The first thing you'll need is thicker foil, the foil on milk bottles is/was much thicker than kitchen foil.
#362350 - 08/08/2014 14:27 Re: Foil milk bottle tops? [Re: Roger]
Simple question:
How?
A hand-held induction sealer, most likely.
#362355 - 09/08/2014 11:42 Re: Foil milk bottle tops? [Re: Roger]
Do you plan on drinking what is inside ???
We use a Aluminium Foil Tape when setting out fireworks, it's sold in screw fix and the like. Often used in window seal and the like. You could fake a top with this stuff without much difficulty. Of course it would be sticky on the underneath and wouldn't be the proper way of doing it.
http://www.screwfix.com/p/aluminium-foil-tape-silver-72mm-x-45m/50629
#362362 - 11/08/2014 08:41 Re: Foil milk bottle tops? [Re: Cris]
Yeah. It's for a fancy-dress party, and I was planning on putting White Russians in the bottles...
#362366 - 11/08/2014 10:30 Re: Foil milk bottle tops? [Re: Roger]
How about using corks / rubber stoppers instead?
#362448 - 31/08/2014 18:07 Re: Foil milk bottle tops? [Re: Roger]
g_attrill
Loc: Hants, UK
Late reply laugh AFAIK they are/were just crimped on, so thicker foil press down and then hard around the edge should work fine? Maybe run a knife around the rim to get a clean look.
Edited by g_attrill (31/08/2014 18:07)
