#36241 - 10/08/2001 04:40 are there problems with the djsa 220 ibm 20 gig
silvercas
welp I decided for now that i Need a 20 gig drive as my second drive. I was originally going to get that new 48 gig as the 2nd but decided for now the 20 gig will sufice ( beside save me some money). Are there any problems with this drive and my original 6gb in my mkII?
#36242 - 10/08/2001 05:32 Re: are there problems with the djsa 220 ibm 20 gig [Re: silvercas]
edwin
Loc: Druten, The Netherlands
I've had no troubles with my factory installed IBM 6Gb and added IBM 20Gb drives, so far... Please do read the FAQ about upgrading very thoroughly, It has some hints and tips you are looking for (washers, isolation).
Good luck!
Edwin de Vaan
mk2 rev.7 # 080000263 (queue 1232) 6+20Gb blue/red
[white]ญญ______________[/white]
Edwin de Vaan aka FLaSHmAStER
#36243 - 10/08/2001 05:40 Re: are there problems with the djsa 220 ibm 20 gig [Re: edwin]
silvercas
yes thats what I did.. I read about the washers and other things.. just wanted to make sure nothing else exisited!
#36244 - 10/08/2001 05:51 Re: are there problems with the djsa 220 ibm 20 gig [Re: silvercas]
I installed a DJSA 220 in my empeg and it works perfectly, save the problem I had with the jumper falling off, but that was my fault. Use some electrical tape to keep the jumper on if you have similar problems.
-Tony
MkII #554
#36245 - 10/08/2001 09:43 Re: are there problems with the djsa 220 ibm 20 gig [Re: tonyc]
synergy
When I just did my 30G upgrade, I used a drop of solder on the jumper... I'm not taking any chances... Taking the cover off once was quite enough for me, thank you very much. I really didn't enjoy working that close to the display board.
