#362434 - 30/08/2014 14:43 CD ripping on Linux?
Linux Mint; command-line (no GUI). No encoding -- just WAV. FreeDB lookup optional, but preferred.
I've tried 'jack', but it didn't quit when it had finished, didn't rename the files according to the FreeDB data, the progress window is _ugly_, and various other problems.
Ideas?
#362435 - 30/08/2014 14:46 Re: CD ripping on Linux? [Re: Roger]
How about the cdfs-src package ?
Never used it myself, but the idea is it allows one to mount an audio CD as a filesystem, where each track appears as an ordinary WAVE audio file that can be copied off.
#362436 - 30/08/2014 15:20 Re: CD ripping on Linux? [Re: Roger]
Oh, easier:
cdparanoia --output-wav --batch
Or just Google it: https://www.google.ca/#q=linux+command-line+cd+ripper
Edited by mlord (30/08/2014 15:24)
#362437 - 30/08/2014 15:39 Re: CD ripping on Linux? [Re: Roger]
Yes, if you don't care about FreeDB lookup, or don't care about combining it with ripping, then you still can't do better than good old-fashioned cdparanoia. FreeDB's tags are best viewed as a "good first draft" and often need a bit of editing.
#362438 - 30/08/2014 15:50 Re: CD ripping on Linux? [Re: peter]
I generally use them as a hint to MusicBrainz.
#362442 - 31/08/2014 08:59 Re: CD ripping on Linux? [Re: Roger]
My solution to Linux CD ripping is a copy of dbPoweramp running on WinXP in a VirtualBox instance. There really is no better CD ripper than dbPoweramp.
It is the same VBox instance that I ran on three machines simultaneously when reripping to FLAC the other year.
#362443 - 31/08/2014 09:38 Re: CD ripping on Linux? [Re: Roger]
Vbox needs a GUI, so disqualified here. smile
There are lots of very good GUI rippers native to Linux.
#362444 - 31/08/2014 16:07 Re: CD ripping on Linux? [Re: mlord]
I've never fired up the VBox GUI on my Linux box. VBox provides RDP access to all the instances wink
#362445 - 31/08/2014 16:09 Re: CD ripping on Linux? [Re: mlord]
There are good CD rippers for Linux, but none of them are as complete and good as dbPoweramp.
#362447 - 31/08/2014 17:11 Re: CD ripping on Linux? [Re: Roger]
Back in the day I used 'rip', a Perl script that handled things nicely and did exactly what I think you want it to do.
Take a look: http://rip.sourceforge.net/ - last updated in 2003 but it should still be pretty useful.
#362453 - 01/09/2014 10:29 Re: CD ripping on Linux? [Re: Roger]
julf
My favourite is morituri
Command line, musicbrainz and accuraterip support, test and copy etc., and written in python.
