#3659 - 03/02/2000 11:43 Need Help on setting up new HDD
erico
Loc: California, USA
I don't know if my drive might be going out. I hear this weird noise that I didn't notice before. Can somebody help me out on setting up a new HD. I already have a HD that fits the empeg stanard. Thanks!!
eric
#3660 - 10/02/2000 13:11 Re: Need Help on setting up new HDD [Re: erico]
Sorry I didn't reply to this one sooner. I assumed someone else would point you to this link. Dmoore has step-by-step instructions on putting a new hard disk into an Empeg:
http://www.dmoore.com/empeghdd.htm
-- Tony Fabris -- Empeg #144 --
Caution: Do not look into laser with remaining good eye.
#3661 - 10/02/2000 20:49 Re: Need Help on setting up new HDD [Re: tfabris]
dionysus
Loc: San Francisco, CA
...and if your current drive is dying, then what you'll want to do it toss a new drive in their as the primary, load up a new version of the empeg software (9c right now) so that the drive is partitioned correctly w/ an empty playlist, then hook up the second drive and copy the data from /drive1 over to the appropriate place in /drive0 ... (This method can also be used to replace the primary drive with a larger one..)
#3662 - 14/02/2000 11:51 Re: Need Help on setting up new HDD [Re: dionysus]
erico
Thanks!! That what I did.
eric
