#370009 - 09/12/2017 22:00 Dead Compact Flash Card -- Boo....
benjammin
Loc: Champaign, IL
Thankfully Empegbbs and the Wiki are still in place or I wouldn't remember how to put in a new hard drive.
So thanks to the admins for keeping things around for us die-hards that will probably putting our Empegs in our freaking Wills.... wink
-Ben
#370010 - 09/12/2017 22:07 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Maybe I spoke too soon -- where's the awesomeness Wiki?!?
-Ben
#370012 - 09/12/2017 22:21 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
Locked away in the admin's files. We've pleaded for it, or a copy of it to mend, but no luck thus far. Someday perhaps.
#370015 - 10/12/2017 00:18 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Hey there! Thanks for the reply.
Wow -- that sucks... frown
Meanwhile, I've never set up jEmplode for pushing empeg images...
I'm using CentOS 6.x which has the RXTX library available from EPEL... (which I installed)
but when I run jEmplode, I still get:
java.lang.NoClassDefFoundError: javax/comm/CommPortIdentifier
This is what the RPM package provides:
/usr/lib64/rxtx
/usr/lib64/rxtx/librxtxI2C-2.2pre1.so
/usr/lib64/rxtx/librxtxI2C.so
/usr/lib64/rxtx/librxtxParallel-2.2pre1.so
/usr/lib64/rxtx/librxtxParallel.so
/usr/lib64/rxtx/librxtxRS485-2.2pre1.so
/usr/lib64/rxtx/librxtxRS485.so
/usr/lib64/rxtx/librxtxRaw-2.2pre1.so
/usr/lib64/rxtx/librxtxRaw.so
/usr/lib64/rxtx/librxtxSerial-2.2pre1.so
/usr/lib64/rxtx/librxtxSerial.so
/usr/share/doc/rxtx-2.2
/usr/share/doc/rxtx-2.2/AUTHORS
/usr/share/doc/rxtx-2.2/COPYING
/usr/share/doc/rxtx-2.2/ChangeLog
/usr/share/doc/rxtx-2.2/INSTALL
/usr/share/doc/rxtx-2.2/README
/usr/share/doc/rxtx-2.2/TODO
/usr/share/java/RXTXcomm.jar
In the longer form of the error box that pops up in jEmplode:
at org.jempeg.empeg.manager.dialog.UpgraderDialog.<init>(UpgraderDialog.java:155)
at org.jempeg.empeg.manager.dialog.UpgraderDialog.<init>(UpgraderDialog.java:114)
at org.jempeg.empeg.manager.action.UpgradeAction.actionPerformed(UpgradeAction.java:62)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.Component.processMouseEvent(Component.java:6516)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3311)
at java.awt.Component.processEvent(Component.java:6281)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4872)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4698)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2718)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747)
at java.awt.EventQueue.access$300(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:706)
at java.awt.EventQueue$3.run(EventQueue.java:704)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:720)
at java.awt.EventQueue$4.run(EventQueue.java:718)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:717)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:218)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:133)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:122)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:118)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:110)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Caused by: java.lang.ClassNotFoundException: javax.comm.CommPortIdentifier
at java.net.URLClassLoader$1.run(URLClassLoader.java:359)
at java.net.URLClassLoader$1.run(URLClassLoader.java:348)
at java.net.URLClassLoader.findClass(URLClassLoader.java:347)
at java.lang.ClassLoader.loadClass(ClassLoader.java:425)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:312)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
... 41 more
But do I need to do anything else? (how do I test the jar file is being referenced properly? I assume it is having been packaged by the EPEL folks..)
(I created javax.comm.properties in /usr/lib/java/ but that doesn't seem to help.)
Thanks,
-Ben
Edited by benjammin (10/12/2017 00:50)
#370018 - 10/12/2017 02:33 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
Try a different Linux distro, one far removed from Redhat/CentOS. It will probably work then.
#370020 - 10/12/2017 02:57 Re: Dead Compact Flash Card -- Boo.... [Re: mlord]
benjammin
Loc: Champaign, IL
LoL -- Don't hold back! Tell us how you really feel!! :P
Anyone else?
Edited by benjammin (10/12/2017 02:57)
#370021 - 10/12/2017 03:50 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Mmmm. Nothing like copying GB of music files at 10Base-T speeds.
LoL...
wait -- some of you may appreciate this...
I had to fix a Cisco Switch with a failed firmware upgrade.
14MB w/Xmodem @ 57600B/s --- hahaha... took like 2.5 hours.
(but it worked!)
#370030 - 10/12/2017 07:26 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
Faolan
Welcome! And glad you got it working again. The Green empeg lives on!
#370036 - 10/12/2017 16:38 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Heh -- yea... I didn't have any doubt it would live on -- just the CF card died.
Such a shame. Solid State devices aren't supposed to go kaput like that.
This one was only 5 or so years old. I kinda expect more life than that.
#370060 - 11/12/2017 17:24 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
Faolan
/usr/lib64/rxtx
Was the fix ultimately finding a 32bit version of rxtx? Or did you go another route to push images to the empeg ahead of getting it back on ethernet?
#370066 - 12/12/2017 02:12 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Ha -- I ended up booting up the VBox VM of my old winXP Dev System to use Emplode to install the image. (my current windows 7 Pro/64 system is unstable with USB RS232 dongles. BSoD in 20-freakin-17.
Sad. Bigly Sad.
I'll figure out the RXTX thing at some point.
#370067 - 12/12/2017 02:13 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Ugh -- Now I'm trying to re-install the web pages (weblite) and can't remember the right syntax for mounting the drive RW so I can copy the files over. frown
(or is there an easier way to push the single default.xsl and it's little subdir to the system?)
-Ben
#370070 - 12/12/2017 12:03 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
rw ; rwm
#371878 - 22/04/2019 20:48 Re: Dead Compact Flash Card -- Boo.... [Re: benjammin]
benjammin
Loc: Champaign, IL
Hey Roger - Thanks for the note (and the Empeg site is back up too!)
I also came to find that I'm not getting emails notifying me of replies and such. Erp.
Sorry for the delay -- but thanks again for helping with my brainfart. :P
-Ben
