#371844 - 27/03/2019 20:39 How do I apply a .upgrade file from Linux?
- emptool doesn't build on recent versions of Ubuntu.
- nor, it turns out, even on debian potato under docker.
- the upgclient binary mentioned on the BBS no longer exists.
- I can't use Mark's upgrader, because I don't have a working disk in this player, which means that it doesn't appear on Ethernet.
#371845 - 27/03/2019 21:04 Re: How do I apply a .upgrade file from Linux? [Re: Roger]
Use one built on an older system then. I have attached static linked versions here for you.
emptool-v2final.static (378 downloads)
upgclient-v2final.static (349 downloads)
emptool-v3a11.static (360 downloads)
Edited by mlord (27/03/2019 21:07)
#371847 - 27/03/2019 21:26 Re: How do I apply a .upgrade file from Linux? [Re: mlord]
Thanks.
Unfortunately, I'm getting "ERROR: 9 Flash program failed" frown
#371848 - 27/03/2019 21:30 Re: How do I apply a .upgrade file from Linux? [Re: Roger]
What I've tried so far (using mSATA disks with a PATA adapter):
- I used your upgrader to extract the parts from the upgrade file.
- I used your download to write the various flash parts.
- I managed to persuade minicom to drop me at the "pump>" prompt, and got it to partition the disk, but it turns out that the protocol for sending disk images is a bit awkward, and basically impossible to sanely script in minicom. And I don't feel like writing any (probably Python) code this evening.
So: I've ordered a USB-to-mSATA adapter (as in: I literally pressed the Checkout button as you posted those binaries), which should arrive tomorrow. I plan to apply the disk image using that.
#371854 - 29/03/2019 15:09 Re: How do I apply a .upgrade file from Linux? [Re: Roger]
It lives!
Est. Free Space: 223GB
My blog: Installing an mSATA disk in an empeg, wherein I use my Linux desktop PC and a bunch of Mark's utilities to persuade everything to work.
#371855 - 29/03/2019 17:16 Re: How do I apply a .upgrade file from Linux? [Re: Roger]
Peachy. I've now saved a copy of your instructions for the next time I might need to do something similar!
#372023 - 27/05/2019 17:34 Re: How do I apply a .upgrade file from Linux? [Re: Roger]
I have been working on an updated bigdisk builder image, and one thing I have noticed is that using -b4096 on the mkfs.ext2 line results in some programs being confused about the actual size of the resulting filesystem.
Eg. "df -h" on the empeg reports a much smaller than expected size. That doesn't really matter, but I wonder what else might be messed up by it?
So.. I'm dropping use of -b4096 from the new builder.
