#373203 - 14/02/2021 23:41
Help me ID these potentiometers and switches
I'd like to find Digikey ordering numbers for these guys, to order replacements, but my searches there aren't working, nothing is coming up which looks anything like what I've got here. Anyone know how to ID these? Photos attached.
These are parts from a joystick, Thrustmaster T-Flight HOTAS 4 model. The pots are for X/Y axis and the rudder rotation axis, and the switches are for the 4-way thumb-hatswitch.
Switches are temporary pushbuttons with a sort of a "click" to them when they are pressed. Potentiometers have a limited rotation travel range of about 270 degrees total, though I don't have an easy way to measure that accurately to be sure. I'm hoping that the printed codes on there are some kind of a clue to their detailed specs.
Thanks for any advice or help you can offer!
Potentiometer - 9.9mm wide 01.JPG (521 downloads)Potentiometer - 9.9mm wide 02.JPG (668 downloads)Potentiometer - 9.9mm wide 03.JPG (365 downloads)Pushbutton Switch - 6mm wide - 01.JPG (207 downloads)Pushbutton Switch - 6mm wide - 02.JPG (128 downloads)Pushbutton Switch - 6mm wide - 03.JPG (128 downloads)
#373204 - 15/02/2021 00:52
Re: Help me ID these potentiometers and switches
You may be interested in this repair service. https://www.ebay.ca/itm/233195609114I have used the bn880 repair service for a different electronic product and was entirely satisfied with the turnaround time, the pricing and the repairs. He works through ebay for the repair billing and initial communications. I do not know if he would be willing to just sell the repair parts. Possible?
#373206 - 15/02/2021 02:46
For the pots, more info would be required to find a suitable match. Eg. the overall resistance (10K-Ohm?), whether it is linear (most likely) or logarithmic.
With that info, a Digikey search should be possible. They don't carry everything though.
#373207 - 15/02/2021 13:32
For the pot, the B104 tells you it's a linear taper 100K. Here's a similar pot that would probably work: https://www.digikey.com/en/products/deta...pQFgBkACEAXQF8gThis part number is for the shaft with the flat, although the picture doesn't show that.
Edited by larry818 (15/02/2021 13:33)
#373208 - 15/02/2021 20:40
Mark, thanks for the switch links. Theoretically any momentary SPST switch will work as long as it's the same dimensions, so that is very useful.
I dismantled my troublesome switch under magnification, and it was a normal dome switch on the inside. It looked like it was manufactured with poor QC, and there was a lot of blackness on the dome and the contact points, as if the black plastic had outgassed or "bled" during the manufacturing. Cleaning it with isopropyl and re-assembling has made it work fine again, but I intend to order more replacement switches just so I have more on-hand so that future repairs are easier.
#373209 - 15/02/2021 20:48
[Re: larry818]
Larry, thanks so much for the ID of the pot. I was indeed hoping that the numbers printed on it would indicate its specifications. Where can I find a reference source for how to read those identification numbers? Some googling gets me a lot of links for guitar amps, and the larger pots in those amps seem to use different types of coding numbers. For example, though I see that "B" means linear taper, I don't see how "104" indicates 100K?
Thanks so much for the link, it will get me started on the right track. Though the particular pot that you linked doesn't look like the exact dimensions and shaft, I will start there and keep looking to find one with correct shaft/dimensions. You said that the picture doesn't show the keyed shaft, despite the part number being correct for a keyed shaft. I'm also concerned with the threaded neck, which might not fit the place where the joystick accepts the part. I'll keep looking to be sure I get the right part.
In the meantime, squirting some electronics solvent and isopropyl into the pot has gotten it working normally again. I will still find and order more replacements for the future: Cleaning only works on these things for a limited amount of time.
#373210 - 15/02/2021 20:51
[Re: K447]
K447, thanks so much for the link to that repair service. I will check them out.
#373211 - 15/02/2021 21:03
104 = 10 with four extra zeros appended = 100000.
#373212 - 15/02/2021 21:44
That alcohol will clean the pot but depraves it of any lubricant. I use this stuff: https://www.learchem.com/products/acf-50.htmlI soak my new pots in it as they tend to wind up in corrosive environments. This stuff protects them and adds a lubricant layer much better than what they come with. Yeah, what Mark said. Also, an A prefix is "Audio taper" and B is "Linear taper".
#373213 - 16/02/2021 19:32
[Re: larry818]
Thanks so much, Larry and Mark, I'll see about finding some of that pot lubricant. Good information.
#373409 - 30/07/2021 02:46
I have found these, based on this reddit thread. - CTS Electronic model 251B12T104A2NB- These have a 12mm shaft though the original has only a 7mm shaft. [EDIT: I measured the original wrong, they actually both have the same shaft length] - However their "Throw", the lock-to-lock sensitivity, is a hair "short" of the actual joystick extremes, compared to the original, when viewed in the joystick control panel software. One might be able to overcome this by setting the joystick sensitivity up a hair in the game. I've soldered a couple in, and I'm going to try them out in-game when I get a chance.
#373410 - 30/07/2021 22:41
The issue is that when I plug it into a joystick testing program, the new pots are kind of "off center", I guess is the correct way to describe it.
The joystick decides what "center" is when you first plug it in. This is the "0" point on the potentiometer. If the joystick is "relaxed" when you plug it in (its springs have it sitting at its center point) then theoretically you should have full range of values in the computer readout. But that's not what's happening. When I plug it into the computer, it shows these values with the new pots:
X-axis, stick full leftwards: -32768 X-axis, stick full rightwards: 30711 (or a bit higher if I push really hard) Y-axis, stick full backwards: 32767 Y-axis, stick full forwards: -31226 (or a bit higher if I push really hard)
Whereas the original potentiometers give me full range -32768 through 32767 for both axes.
Seems "OK" in-game so I'm not "too" worried about it. I just wonder if I'm not getting my full turning rate in my X-Wing when I'm banking right or diving. The way this thing is constructed, there's no way to "adjust" the pot positions, it's all plastic snap-in-place stuff and the shafts of the pots are D-keyed.
#373412 - 31/07/2021 15:21
[Re: larry818]
Indeed I had the same thought. I'm looking but I can't find pots with tighter tolerance. The datasheet for the CTS ones that I linked, says that 10% is their best version, their others are 20% and 30%. Searching for pots with the same physical dimensions keeps leading me back to that CTS one.
#373415 - 01/08/2021 01:05
[Re: larry818]
Excellent question. The joystick travel, lock to lock, is actually a very small portion of the overall travel range of the potentiometer. I haven't got an easy way to measure it, but it seems like it's probably something like 45-50 degrees worth of total travel. So the pots in the joystick are only using a small pie slice of the total capabilities of the pot. So it would make sense that if the tolerance of the pot varied by as much as 10 percent, then I'd indeed expect it to make a visible difference like the one I'm seeing. If I were the one designing the thing, I wouldn't use cherry picking to get homogeneity. I'd fix it in the electronics or the joystick firmware. For example, via trim pots on the circuit board (I didn't see any but I'll double check), or write the firmware so that it corrected for pot variance over time. I briefly tried adding a second pot to act as a trim pot, but it made things worse and was too fiddly to be able to make a good adjustment anyway. I think it's probably actually OK in the game, and I don't really need to do anything to correct this, most of this is just an interesting tech exercise for me.
#373416 - 01/08/2021 06:44
Loc: Squamish, BC
It's not uncommon for the mechanical range of travel and the electrical range of travel of a potentiometer to vary significantly. For example, in the 251B12T104A2NB model referenced, the mechanical range of travel is specified as 180 degrees, whereas the electrical range of travel (sometimes called the effective electrical angle) is 50 degrees. The datasheet shows how to decode the part number to find the electrical range of travel, indicated by the number in the third-to-last position of the model number, in this case 2. However, the datasheet on the Mouser site seems incomplete and doesn't have 2 as a valid value in that position. Digikey have a more complete/up-to-date datasheet here: https://www.digikey.com/htmldatasheets/production/2758000/0/0/1/251-series-datasheet.htmlIn positions outside of the electrical range of travel you'll generally not see any change in resistance, as the wiper is likely in contact with one of the terminals.
#373429 - 04/08/2021 08:18
[Re: snoopstah]
Thanks so much for all this information, everyone.
Interesting that Digikey has a more recent datasheet than Mouser, yet Mouser carries the part in stock but Digikey doesn't.
