#373543 - 21/10/2021 08:03 hard disk problems
Mr_Maniacal
Loc: Salt Lake City, UT
I get a message when I boot up me empeg and it says "No hard disk found." I have checked the cable, how the cable is hooked up, solder joints and the hard drive. Everything is good. What else can I try. I read somewhere about what else I can do. I just can't remember where I found the info about it. I remember something saying you have to send a command to reset some chip. I am out of my element. Can someone please help me. My empeg is one of a few prized possessions. I needs help. If my empeg is toast, I need to find out. I cant live without. I will have to find another one. Before I do that, I need to exhaust every option first.
#373544 - 21/10/2021 12:48 Re: hard disk problems [Re: Mr_Maniacal]
I think the command to reset some chip was for a sound chip, and Hijack has a way to bypass that chip if need be when in that state.
EDIT: The cs4231a chip, here: CS4231A Issues and explanation
First step for trouble-shooting is to capture a full serial port output of the attempted boot sequence, and post it here for examination.
The Empeg FAQ (link above near top left) will have lots of information about all of this.
#373545 - 21/10/2021 19:30 Re: hard disk problems [Re: mlord]
Don't discount the possibility that the hard disk itself is truly bad.
Hard disk diagnostic steps in the FAQ: http://www.riocar.org/FAQ/8/221.html#221
Get that boot log and post it so Mark can look at it. smile
#373596 - 21/11/2021 07:21 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
Here is the full serial port output of the attempted boot sequence:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v508 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Fri Jan 9 16:06:35 EST 2009
Processor: Intel StrongARM-1100 rev
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 10101518) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
show_message("Hijack v508 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
CS4231A: not responding (88) --> no visuals for Tuner/AUX
empeg usb initialised, PDIUSBD12 id 0000
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
RAM disk driver initialized: 16 R
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0xfe3d
ide_data_test: wrote 0xffff read 0xfe3d
ide_data_test: wrote 0xaaaa read 0xfe28
ide_data_test: wrote 0x5555 read 0xfe15
ide_data_test: wrote 0xffff read 0xfebd
ide_data_test: wrote 0xaaaa read 0xfea8
ide_data_test: wrote 0x0000 read 0xfe35
ide_data_test: wrote 0x5555 read 0xde15
ide_data_test: wrote 0x5555 read 0xfe35
ide_data_test: wrote 0xaaaa read 0xfe3d
smc chip id/revision 0x0601
smc_init couldn't find card
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...VFS: Cannot open root device 03:05
Kernel panic: VFS: Unable to mount root fs on 03:05
There is the boot up. Let me know if you can find something wrong or if I did something wrong getting the info.
#373597 - 21/11/2021 19:17 Re: hard disk problems [Re: Mr_Maniacal]
The CS4231A, USB, and ethernet chips are all reporting problems. One or more of those has likely died, tying up the data bus for the others as well as for IDE.
Or.. possibly the IDE cable is plugged in backwards?
Unplug it completely, and leave it unplugged and capture another boot trace.
Edited by mlord (21/11/2021 19:18)
#373598 - 21/11/2021 19:24 Re: hard disk problems [Re: mlord]
Mr_Maniacal
ok. will do. I will get back to you.
#373599 - 24/11/2021 05:46 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
here is the boot sequence with the hard drive unplugged.
hijack: Remounted read-only: /
show_message("Remounted read-only")
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004400).
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffff
ide_data_test: wrote 0x5555 read 0xffff
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:05:e
e
take a look.
thanks
#373600 - 24/11/2021 06:02 Re: hard disk problems [Re: Mr_Maniacal]
So.. USB is now ok, Network chip is fine, and CS4231A also looks good.
The problem must be something to do with the drive(s) on the IDE cable, or perhaps the cable was incorrectly aligned or reversed on a connector?
#373601 - 24/11/2021 07:28 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
when I sent it to a computer shop to check the hard drive, they checked the hard drive and said it was fine and also replaced the cable. I will hook the cable that you sent me with and let you know what happens.
#373602 - 24/11/2021 14:37 Re: hard disk problems [Re: Mr_Maniacal]
The other "usual suspect", is that perhaps some pins have broken free of their solder joints on the IDE header on the mainboard of the empeg.
It doesn't look like that to me from the logs, but just about anything can go wrong when the the right (wrong) pins break free there.
#373603 - 25/11/2021 01:35 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
when I had the hard drive checked, they used a different ide cable and hooked it up wrong. No the hard drive spins up. The empeg still doesnt find the hard drive. Here is the new boot log.
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004800).
ide_data_test: wrote 0x0000 read 0x0280
ide_data_test: wrote 0xffff read 0x0280
ide_data_test: wrote 0xaaaa read 0x0280
ide_data_test: wrote 0x5555 read 0x0280
ide_data_test: wrote 0x0000 read 0x0200
ide_data_test: wrote 0xaaaa read 0xaaaa
ide_data_test: wrote 0x5555 read 0x5755
hda: KBO-FJSA/230" " " " " " " " " " " " " ", ATA DISK drive
hda: KBO-FJSA/230" " " " " " " " " " " " " ", 8063MB w/1874kB Cache, CHS=16383/1
6/63
e
Partition check:
hda: hda1 < > hda2 hda3 hda4
Press Ctrl-A to enter pump...attempt to access beyond end of device
03:05: rw=0, want=2, limit=0
dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024 count=1
EXT2-fs: unable to read superblock
see what you can determine from that. I have tried to look at the pins and it doesnt seem that any are disconnected.
#373604 - 25/11/2021 01:41 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
At the top of my previous post it should say now the hard drive spins up instead of "No the hard drive spins up."
#373605 - 25/11/2021 02:49 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
I also tried another spare hard drive that I have, but I dont think it has been formatted. It gave the same boot info except the partition info was different.
says
partition check
hda: unknown partition table
otherwise everything else was the same.
#373606 - 25/11/2021 22:52 Re: hard disk problems [Re: Mr_Maniacal]
Well, the chips all looked good with no IDE cable in there, so the only possibility for me is that the cable is bad, or the solder joints on the IDE header on the mainboard have come loose.
#373607 - 26/11/2021 01:02 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
I have used 3 different cables. They all show the same boot up. It looks like the solder joints are fine, but I will have a professional look at them.
#373608 - 26/11/2021 07:59 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
i used my original cable and made sure itwas plugged in all the way. The end that plugged into the board was a little loose. it detects the hard drive. this is the boot up.
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004c00).
ide_data_test: wrote 0x0000 read 0x0080
ide_data_test: wrote 0xffff read 0x0080
ide_data_test: wrote 0xaaaa read 0x0080
ide_data_test: wrote 0x5555 read 0x0080
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0x5555 read 0x5555
hda: IBM-DJSA-230, ATA DISK drive
hda: IBM-DJSA-230, 28615MB w/1874kB Cache, CHS=58140/16/63
e
Partition check:
Mounting proc
No secondary hard disk
Press Starting player
Timezone: EST
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
player.cpp : 587:empeg-car 3.00-alpha11 2005/07/25.
Prolux 4 empeg car - 2.1485 Jul 25 2005
Vcb: 0x4073a000
#373609 - 26/11/2021 14:17 Re: hard disk problems [Re: Mr_Maniacal]
That looks fine.
#373610 - 26/11/2021 17:28 Re: hard disk problems [Re: Mr_Maniacal]
Mr_Maniacal
I tested everything and it works great. Its just that the original cable must have worked itself loose. I dont know why the other brand new cables dont work though. I am happy once again. Thanks for the help. I am glad it wasnt something really serious. Now I need to make sure it doesnt wiggle itself loose again. Any suggestions?
#373611 - 26/11/2021 18:27 Re: hard disk problems [Re: Mr_Maniacal]
The "factory" used to add a small dab of hot-melt glue to hold the cables to the hard drives. One could attempt something similar at the other end of the cable, but only a very small dab of glue, and preferably not over too many surface-mounted components of the mainboard.
