#374243 - 15/01/2024 18:42 Panel punching
Hi,
I wonder if anyone knows of an online source for cnc punching or some other way I can make panels for my projects?
In the past, I've had a local metal shop cnc punch powder coated aluminum for this, but they charge kind of a lot and lately don't do good work.
I'm assuming there's online services for this now, but my search-fu is failing me.
Here's what I'm trying do to:
[img]https://scontent-lax3-2.xx.fbcdn.net/v/t...amp;oe=65CCD729[/img]
That thing in behind the keyboard. It's a PLC test rig.
Thanks,
Larry
#374245 - 17/01/2024 11:02 Re: Panel punching [Re: larry818]
You'll get a cleaner cut with something like this won't you?
https://xometry.uk/laser-cutting/?utm_so...ASAAEgIEXvD_BwE
#374246 - 18/01/2024 05:24 Re: Panel punching [Re: larry818]
What about from China from one of the places more known for PCB fabrication like PCBway? They do all sorts of fabrication these days like CNC cutting, 3D printing etc.
#374247 - 18/01/2024 09:18 Re: Panel punching [Re: Shonky]
There's also places like https://www.emachineshop.com/ - I don't know if they are any good, I have never tried them, I'm just giving an example of the type of business.
#374249 - 28/01/2024 11:15 Re: Panel punching [Re: larry818]
Thanks! I'll contact those places.
The cnc punch leaves surprisingly clean cuts, if the machine isn't filthy. Laser leaves the edges way too sharp.
