#374590 - 04/04/2025 08:21 SSD Capacity
Was just thinking last night, why are higher capacities higher prices?
Surely pretty much everything is materially the same between a 1TB and 2TB capacity, where does the extra cost come in?
I used to think this with HDDs but I guess there were drives with higher numbers of platters or higher densities or whatever, but these are just silicon right?
#374591 - 04/04/2025 11:40 Re: SSD Capacity [Re: tahir]
2X as much flash memory is needed for 2X the storage. That's either more chips, or chips with more stacked layers.
#374592 - 07/04/2025 01:08 Re: SSD Capacity [Re: mlord]
And even if it's not more layers, I'd bet that a chip with higher density circuits requires more expensive fabrication and QA systems. And I'll bet the yield is lower too (number of good chips you get out of a manufactured batch).
#374594 - 14/04/2025 09:15 Re: SSD Capacity [Re: tahir]
Good points both, I should have thought about the yield thing, that I guess is pretty obvious.
