Beta 1 will be released to the alpha test team tonight, and if they don't break it horribly it will go public on Monday. If they do break it horribly, we might release their home addresses to the BBS *grin*
To maximise the anticipation, I've decided to post the release notes to the BBS. This will give you time to familiarise yourselves with the new feature list - and hopefully persuade you that we haven't just made the whole thing up!
Enjoy.
Rio Car Beta Release 05-October-2001
Version 2.00-beta1
Copyright (c) SONICblue, Inc. 2001
* Notes
This is a Rio Car beta release. BY DEFINITION, BETA SOFTWARE MAY NOT
PERFORM AS ADVERTISED. It may not be stable. It may eat your music
and spoil your day in any number of ways. Please do not install this
release unless you understand these important points.
Release 2.0 has been in development for many months. These notes are
by no means comprehensive, if you notice a significant new feature that
isn't mentioned then please let us know so we can add it to the list.
* General
Please submit bugs to
[email protected] - preferably after reading
the BBS (http://empeg.comms.net) to check that the bug has not already
been discussed.
Release notes are not cumulative. If you are upgrading by more than one
release then please read each set of release notes.
* Installation
Download either the consumer or developer images and emplode (or emptool)
from the empeg-car upgrades site.
You should install the new emplode or emptool before installing this
release. If you fail to do so your empeg-car unit may not function and it
will be necessary to apply the upgrade again using the correct version of
empegUpgrade or upgclient.
We strongly recommend completely de-installing the previous emplode before
installing the new one, which installs into a different location.
Connect your computer to your empeg car using the supplied serial cable.
Switch off your player at the wall or unplug the IEC cable from the brick
power supply.
The upgrade can be installed by serial only. Run the Upgrade Wizard and
either enter or browse for the upgrade file. Click Next and select the
serial port that your unit is connected to. Click Next again.
When instructed to do so by the upgrade program re-apply power to your
player by switching it on at the wall or connecting the IEC cable and brick
power supply. If you have an all-in-one power supply then switch it on at
the wall if possible or plug into the wall. The upgrade should then be
applied. If it fails, try again.
* What's New Since 1.03 - Player
NB: Features which require a real time clock may not work on Mk.1 players.
MP3 playback is now done using the ARM decoder. There should be little in
the way of audible difference but the VBR support is much improved, and
certain tracks that would not play before may now play.
WAV files are supported.
WMA files are supported, apart from DRM encrypted files.
Significant improvements to caching performance (turn on the disk
indicator to see this in action).
Gapless playback of properly-constructed MP3 files has been improved. Note
that this is dependent upon how the MP3s were created - most MP3 encoders
will add artificial silence to the beginning and end of each track as it
is being created. The car player will no longer insert its own gaps between
two consecutive tracks on playback.
Play counts and last played times have been implemented.
The running order and programme are now preserved over synchronise
operations.
Three bookmarks may now be stored and restored.
Repeat modes are now selectable from the player itself. An "r" (repeat all)
or "R" (repeat track) appears in Track info modes.
Tracks can now be marked for attention on the player. This is done by
pressing "7" on a Kenwood remote or "Mark" on a Rio remote. The function
is also available from the Bookmarks menu (we're looking for a more logical
home for it). Marked tracks appear in emplode with a distinguishing icon,
and can be a search criteria.
It is now possible to toggle timecode display modes by pressing "1" on the
remote. It is marked with "Time" on the Rio remote. Display modes are:
- Time of Day
- Track Elapsed
- Track Remaining
- Total Elapsed
- Playlist Elapsed
- Playlist Remaining
- Playlist Elapsed / Remaining
A number followed by "d" indicates days (!).
Balance, beep volume, and loudness are now remembered separately for in-car
and in-home use.
Several alternative shuffle behaviours have been added..
- Random: As before
- Least often played: Tracks played less often will tend toward the start
- Least recently played: Tracks played less recently will do as above
- By year: There will be an approximate progression through history
- Off: As before
Toggling shuffle with the remote will switch between no shuffle and the
last shuffle mode selected. When shuffle is active an "S" is shown on
the Track info screen.
Shuffling the running order is now much less likely to glitch the audio.
When selecting tracks to play using the musical note icon only the tracks
are played, not the playlists.
It is now possible to skip tracks/fast forward/rewind while the disk is
spun down with the UI not hanging.
Soft power on/off now works during synchronise.
It is no longer possible for the player to pick the wrong menu item if an
item is selected very quickly after moving to it.
Wendy filters have been implemented. These provide a means to completely
hide content on a player, for example if your mother is in the car.
Filters can be combined for more advanced applications. They are defined
from within emplode. An 'F' appears in track details view if a Wendy
Filter is active.
A new "hush" mode has been added which reduces the volume by a configurable
(from emplode) amount rather than muting it completely. This is achieved
by holding the pause button on the Rio remote (there is no Kenwood
equivalent). An 'H' appears in track details view if Hush is active.
A detailed info screen is now available for tracks. Press and hold the
"Info" button on the Rio remote to see this screen. Not available on the
Kenwood remote.
Pressing the rotary knob now toggles through the various Sound menu
settings (Volume, Balance, etc).
The external mute line can now be configured (from emplode) to cause mute,
pause or hush.
A large number of new visuals have been added, and existing visuals have
been enhanced. Note that there are random elements which reseed from time
to time, so any one visual could have several random looks.
Implemented visuals for Aux-In and Tuner.
A transient line info visual has been added which appears and disappears in
a "Top of the Pops"(tm) style. The graphical visual behind it squashes into
the remaining space rather than clipping. The timecode pops up in isolation
when scanning within a track.
Volume now ramps up gradually at startup when in the car to avoid pain the
morning after the heavy night before. This can be configured from emplode.
DHCP client now does uPnP address allocation in parallel with normal DHCP.
This means it can be plugged directly into a PC with no network setup (ie,
set to "automatic") and ethernet will work.
Time zone now works correctly.
Position is remembered in playlist menus - press and hold the playlist menu
item to return to previous level. This does not currently work across
reboots.
Minor UI enhancements, e.g. round corners of menus.
Added support for insert/appending to playlist when the menu button
is held in the playlist hierarchy. A submenu opens with the appropriate
options.
Added insert as well as append during search. Use "Select Mode" on the Rio
remote or "CDMDCH" on the Kenwood. Multiple insert operations will insert
after the last inserted item, not just after the current play position,
allowing proper cueing of new tracks
Improved download efficiency.
Implemented Hate Music buttons - press and hold the appropriate remote
tweak function to remove tracks from the running order. e.g. If a
Britney track comes on, press and hold Artist (2 on Kenwood) to remove
all further Britney tracks from the running order.
Aux-In detects track transitions, and guesses at track numbers and
timecode.
Fixed the cumulative duration calculations.
The visuals information is now updated via RDS if the selected
channel is FM.
The EQ UI has been changed to allow more features and make things a little
easier for the user. In particular:
- The settings that used to live in the centre of the display have been
moved into a menu structure. Access this by pressing left/right until the
preset name is highlighted in the top centre of the screen, then press down.
- This menu also includes a "copy from" feature for copying entire presets
- The number keys 1-9 select the the n-th band, or the n-th preset
- The rotary can be used to adjust levels, and can be pressed to select
gain/freq/Q adjustment
- Saving has been made automatic
The powerfail indicator now stays on the screen for as long as the voltage
is beneath the threshold.
Long track names now scroll in info screens.
Search By Playlist has been implemented.
When you un-shuffle, the player will properly un-shuffle "around" your current
tune according to the order of the playlists you've specified in Emplode. If
you want the player to always "un-shuffle around the current track" so that
you're dropped into that track's album, then make sure your album trees are
listed first in Emplode (based on the Position column).
* What's New Since 1.03 - Emplode
(emplode has been completely rewritten, what follows is far from
comprehensive. Please refer to the built in help.)
New player discovery dialog, which continuously monitors for players on
the enabled interfaces.
The tree includes views by Artist, Genre, All Tracks and so forth. Tracks
are automatically sorted into these views.
Tracks no longer have to exist within playlists. All tracks on the player
are shown in various views from the tree, of which Playlists is one option.
If a track is erased from all playlists it will not be removed from the
player - this will only happen when it is erased from one of the fixed
views. In future it will be made more obvious to the user whether they
are erasing a reference to a track, or removing the content entirely.
Implemented "emplode today" HTML view. This is the first view presented
when a player is connected, and provides some useful links. Tunes can be
dragged & dropped onto HTML view (in which case they will not be added to
any playlist and will be accessible only from within searches - in future
the emplode tree structure will be recreated on the player).
Now allows drag and drop onto "Artists", "Albums", etc in which case the tags
will be updated appropriately. This is useful for mass retagging of tracks
using multiple views.
Tracks can be dropped onto the player icon in the tree, in which case they
are added as content but not added to any playlists.
It is now possible to scroll whilst dragging and dropping.
A search capability has been added with both simple and advanced
interfaces. Advanced searches can be saved to disk.
Dragging and dropping from Search results onto the tab control switches
tab appropriately.
The free disk space tracking code in emplode is much better, in particular
it now copes with deletions.
Files already on the player can now be trawled automatically to fill in
extra information (such as codec, bitrate etc. information) that has been
supported for newly added files since before v1.0.
Dropping files is now much more user friendly. Items dropped are now sorted
alphabetically by filename.
Implemented Yes to All confirmation in appropriate dialogs.
Dragging an item from the search results onto the tab control in emplode
now switches tabs.
Implemented context menu in RHS views in Emplode.
Implemented redirector URL for product support.
Users can now name AUX channel in emplode, to match whatever hardware you
might have attached.
The volume can be capped at 0dB from emplode.
The Kenwood remote control can be disabled from emplode, to prevent clashes
with other Kenwood head units in the vehicle. The Rio remote uses different
(unique to Rio) codes.
Implemented buttons to allow reordering of tracks.
Group-editing multiple selections has been implemented. For instance, you can
group-select ten tracks, get their properties, and change their Artist field
in a single operation.
Rob Voisey 2001/10/05 20:12 +0100 (BST)
[email protected]
