#40662 - 06/10/2001 23:23 empeg locked up...
Clarke
Loc: Scottsdale, AZ USA
I was playing the unit and all of a sudden it locked up. The display freezes for a while, no buttons have any effect. After a while the player restarts and then freezes again as soon as it's running. The cycle continues forever.
Power off causes the player to reboot and start the cycle all over again.
I re-uploaded 1.03 and ended up with the same problem after the successful completion of the upload.
Serial port reports the following:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 ([email protected]) (gcc version 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 9, serial number 40104221)
Command line: mem=16m temp=45
Memory: 15064k/16M available (960k code, 20k reserved, 332k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004980).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHM2100AT, ATA DISK drive
hda: FUJITSU MHM2100AT, 9590MB w/2048kB Cache, CHS=19485/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:7d
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 8k init empeg-car 1.03.
3b366bc5 DHCP Our mac is 00:02:d7:28:10:7d
3b366bc5 DHCP Our address is 255.255.255.255
3b366bc5 DHCP Broadcast address is 255.255.255.255
3b366bc5 DHCP Current IP address is 255.255.255.255
3b366bc5 DHCP Sending DHCP discover
3b366bc6 DHCP Sending DHCP discover
Starting bash.
no shell!
Shell exit
empeg-car 1.03.
3b366bdf DHCP Our mac is 00:02:d7:28:10:7d
3b366bdf DHCP Our address is 255.255.255.255
3b366bdf DHCP Broadcast address is 255.255.255.255
3b366bdf DHCP Current IP address is 255.255.255.255
3b366bdf DHCP Sending DHCP discover
3b366be1 DHCP Sending DHCP discover
Starting bash.
no shell!
Shell exit
empeg-car 1.03.
3b366bfa DHCP Our mac is 00:02:d7:28:10:7d
3b366bfa DHCP Our address is 255.255.255.255
3b366bfa DHCP Broadcast address is 255.255.255.255
3b366bfa DHCP Current IP address is 255.255.255.255
3b366bfa DHCP Sending DHCP discover
Starting bash.
no shell!
Shell exit
empeg-car 1.03.
3b366c10 DHCP Our mac is 00:02:d7:28:10:7d
3b366c10 DHCP Our address is 255.255.255.255
3b366c10 DHCP Broadcast address is 255.255.255.255
3b366c10 DHCP Current IP address is 255.255.255.255
3b366c10 DHCP Sending DHCP discover
Starting bash.
no shell!
Shell exit
empeg-car 1.03.
3b366c29 DHCP Our mac is 00:02:d7:28:10:7d
3b366c29 DHCP Our address is 255.255.255.255
3b366c29 DHCP Broadcast address is 255.255.255.255
3b366c29 DHCP Current IP address is 255.255.255.255
3b366c29 DHCP Sending DHCP discover
And it repeats forever. (there is a DHCP server on the network by the way). I've emailed support but it's the weekend. I don't want to do without her that long.
Any thoughts from the boards wisdom?
______________________________________
Queue 351, Now Mk II #60000022 18gb, Blue
______________________________________ Queue 351, Mk I, 30GB Mk II #60000022 80gb, Blue - docked Mk2a, 80GB, Bruface, lighted buttons and dial
#40663 - 06/10/2001 23:36 Re: empeg locked up... [Re: Clarke]
Install the developer image, then follow the recovery procedures documented in this thread.
This may need to become a FAQ item, as it seems to be happening more and more...
#40664 - 07/10/2001 00:23 Re: empeg locked up... [Re: drakino]
it sholdn't matter after monday :-)
32Gig MK2 In 2001 VW Golf TDI
#40665 - 07/10/2001 09:01 Re: empeg locked up... [Re: msaeger]
DarkStorm
Loc: Pompano Beach, Florida
Mine was doing somthing similar and it was a bad spot in the mp3.
I got by it pressing the fast forward key repeatadly just as it was getting ready to start playing again.
That did it for me, I was able to get past the bad spot, skip to a different song & make a note of it so I could remove & fix it later.
Steve
Mark I / #102 / 48g / Smoke / Custom Fascia
Best PC/Audio Investment Ever Made
Steve DarkStorm Designs
#40666 - 07/10/2001 21:36 Re: empeg locked up... [Re: drakino]
Clarke
That did it! Thanks Drakino!
I just wish I knew what song was playing so I could forward it to the folks at empeg to dissect.
=-C
