#41843 - 17/10/2001 12:44
clock display in 2.0b3
Loc: Ft Lauderdale, FL
The clock display on the Track screen is only in 24hr format, no matter what I choose. Now, I can figure it out, but some of my passengers may not be able to do the math.
edit: I am using the developer image, if this helps.
-Trevor
Mk 2, Green 12GB, Tuner 080000349 Edited by trevorp on 17/10/01 09:39 PM.
-Trevor
----- Mk 2, Green 12GB, Tuner, 2.0b11, 080000349
#41845 - 17/10/2001 12:58
Re: clock display in 2.0b3
[Re: trevorp]
Hmm, works fine for me. Anyone else? ___________
#41846 - 17/10/2001 13:19
Showing 12 hr format here....
Synergy
[orange]mk2, 42G: [blue] mk2a, 10G[/blue][/green]
I tried Patience, but it took too long.
#41847 - 17/10/2001 13:22
[Re: trevorp]
You need a better class of passenger! One of the few remaining Mk1 owners... #00015
#41848 - 17/10/2001 13:26
Nope, I get 24h clock no matter what.
Process:
Settings -> Clock Format -> 12 hour
Settings -> Timecode -> Clock
Clock appears, but is in 24 hour format.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
#41849 - 17/10/2001 13:30
[Re: phaigh]
Doh! You're right...
The VISUAL clock shows 12 hour format, but the timecode clock does NOT. It seems to be locked into 24.
Synergy
#41850 - 17/10/2001 13:31
[Re: schofiel]
Well, I knew that, but I figured it's easier to fix the time format than to find new friends... -Trevor
Mk 2, Green 12GB, Tuner, 2.0b3, 080000349
-Trevor
#41851 - 17/10/2001 13:37
[Re: synergy]
Groovy!
I get exactly the same!
Did you notice how the individual numbers appear to move when the ':' character comes and goes?
Weird!
Paul.
#41852 - 17/10/2001 14:54
[Re: synergy]
Yeah, I was checking the visual as well. I never use the Info screen clock (always on countdown or elapsed/remaining).
If none of the alpha folks have put that into the internal buglist yet, I'll do it now. ___________
#41854 - 18/10/2001 03:52
Loc: West Midlands, England
Okay, it's on their internal bug list. Case closed. NEXT?
OK. I'll be picky. When time format is set to 24 hour, the analogue clock still displays a 12 hour face.
Hmm. Sounds trivial, but I actually like a 24 hour analogue clockface..
Nicholas.
18GB red s/n 080000299, original pos'n 8724. Reproduction of this post is not permitted.
#41855 - 18/10/2001 04:47
[Re: debauch]
Wow, and I was worried about my passengers not being able to do the math. Imagine them trying to figure out where "the little hand" is pointing to on a tiny clock like that.
-Trevor
-Trevor
#41856 - 18/10/2001 05:31
[Re: phaigh]
That's deliberate -- it's dithering the numbers. It alternates the dither, to reduce screen burn-in.
#41857 - 18/10/2001 05:35
[Re: debauch]
You must be very rarely satisfied then! I vaguely remember seeing a 24h analogue clockface once, but I can't remember where (Crewe Station?).
The Fitzwilliam Museum in Cambridge has a longcase clock showing French Revolutionary time: 10 hours in the day, 100 minutes in the hour. (As Eric Hobsbawm put it, the only lasting effect of the French Revolution was metrication.)
