I get the same thing. How large are your disks? I suspect it is space related.
Maybe not, it has happened to me as well, same code with the exception of the error says 'failed sync while writing player config.'. I was just about to post it, I have only a single 12gig drive in my Mk2.
Happened about five times so far doing various things e.g.- uploading wav files, changing source names for wav files, & other things. If you try to close Emplode you get a popup saying a sync is required if you select yes it gives a 'wrong cookie session' error & you end up having to select no & exiting. When you restart Emplode the file it puked on is there & changed & appears fine.
#695-Mk2/8 colors-12Gig w/Tuner- awaits v2.x & Voice Recog.Edited by jwickis on 18/10/01 03:10 AM.
