#41987 - 17/10/2001 14:03 Emplode 2.03b: Expected behavior?
trevorp
Loc: Ft Lauderdale, FL
I assume the following feature is meant to preserve database integrity?
I had emplode open and connected to my empeg. I then pulled the plug on the empeg and plugged it back in, just to see Tux wave again. Then I tried a sync, and got a message about an invalid cookie.
-Trevor
Mk 2, Green 12GB, Tuner, 2.0b3, 080000349
-Trevor
Mk 2, Green 12GB, Tuner, 2.0b11, 080000349
#41988 - 17/10/2001 14:11 Re: Emplode 2.03b: Expected behavior? [Re: trevorp]
Yup, you shouldn't pull the plug on an open session and then try to synch.
In older versions of emplode, that activity would have given you really bad errors, at least in 2.0 it's got a nice clean message.
It warms the cockles of my heart to know that people are cycling the power just to look at Tux (even the sub-cockle area, for you Dennis Leary fans).
To save wear and tear on your power plugs, remember that you can get the player to reboot simply by sending or deleting custom logos with my logo editor.
#41989 - 17/10/2001 14:14 Re: Emplode 2.03b: Expected behavior? [Re: tfabris]
mcomb
Loc: San Carlos, CA
I have actually called people over to my desk to check it out. Very cool.
-Mike
#41990 - 17/10/2001 17:01 Re: Emplode 2.03b: Expected behavior? [Re: trevorp]
That feature is also a part of a basic password protection system (to prevent casual network access to your unit via emplode) which hasn't been implemented on the player side yet. I believe it is likely to make a 2.x release.
#41991 - 17/10/2001 22:37 Re: Emplode 2.03b: Expected behavior? [Re: tfabris]
borislav
Loc: Sunnyvale, CA, USA
I have an extra power strip on my desk for this exact purpose - it has an on/off switch and only the empeg is plugged into it. The switch has seen more use in the last 10 minutes than in the preceding month or two. Very cool, indeed!
Borislav
#41992 - 17/10/2001 22:40 Re: Emplode 2.03b: Expected behavior? [Re: tfabris]
I think it was Carol Burnett who said, "...and there's nothing worse than a heart full of cold cockles!"
#41993 - 17/10/2001 23:10 Re: Emplode 2.03b: Expected behavior? [Re: rob]
muzza
hate to be picky but...
Can we have this switchable?
Murray
new styleee
#41994 - 18/10/2001 03:55 Re: Emplode 2.03b: Expected behavior? [Re: muzza]
Of course - you won't HAVE to use a password!
#41995 - 18/10/2001 03:57 Re: Emplode 2.03b: Expected behavior? [Re: trevorp]
Yep.
In the future I hope to fix it so it moans about the cookie if the database was actually changed, as opposed to just potentially changed.
