#42726 - 19/10/2001 14:34
clock setting and line clock doesn't set
v2.0b3
Two things i just noticed, that i can't seem to find reports for.
1. I keep having to reset my clock. I just did it for the fourth time. I haven't had a chance to see exactly when it gets off sync... whether it's from AC to DC or what. But it's not when i just pull AC power and plug it back in. I'll watch it more closely to see if i can determine when it happens.
2. The other oddity is that after you reset the clock, the Line Info clock stays at the previous time, while the Visual clock works as would be expected and changes to the newly set time. This is remedied by a power cycling
|| loren.cox ||
#42727 - 21/10/2001 02:34
Re: clock setting and line clock doesn't set
[Re: loren]
Possibly a hardware failure. I've seen one unit with an exploded supercap (which is what runs the RTC when power is off).
#42728 - 21/10/2001 18:14
[Re: altman]
Argh, that's not what i wanted to hear. What would cause that?
Is there any way for me to visually verify if the cap is blown? (i'm guessing so). And if so, is it something i can fix or should it be sent in
Soo.... where is it, my warranty is up and i'm not afraid of cracking the hood again. =]
|| loren.cox ||
#42729 - 21/10/2001 23:48
[Re: loren]
On the right hand side of the PCB, near the back - behind the HDD connector - is a little (maybe 8mm diameter) round cap, with a lead going from the top back down the side of the component to the PCB.
If there is a pool of mush around this, then it's definitely blown (though it could go without such visible signs).
The way to really check is this: get a voltmeter and check the voltage between the top of the cap and the bottom of it (the other pin is just visible on the other side of the cap). It should be around 3.5v-ish. If it's dead, it'll read <0.5v when the empeg is not powered.
#42730 - 22/10/2001 00:42
[Re: altman]
Okay, i took the lid off, and took a picture, which is attached with an arrow pointing to the cap (at least i hope so =).
Doesn't look blown to me... I don't have a voltmeter (i know i know) so i'll see if i can borrow one tomorrow and check it further. Thanks for the info!
|| loren.cox ||
#42731 - 22/10/2001 11:46
[Re: loren]
Could i just replace the cap myself? Or is that a bad idea?
If so could you provide a part number and how much would a cap like that cost me?? Any idea what would have caused the cap to fail?
questions questions questions... =]
|| loren.cox ||
#42732 - 22/10/2001 13:21
[Re: loren]
Yes, you could do it yourself; you'd have to be good at soldering and very careful. I wouldn't recommend it unless you're experienced with electronic rework.
The part number from www.farnell.com is 303-6790, it's £1.43.
No idea what would make it fail, though. It's charged fairly slowly and is rated at 5v (we only use it to about 3.5v max).
#42733 - 22/10/2001 19:05
[Re: altman]
Ran to RatShack on the way home and picked me up a multimeter... finally. Lets see here....
Sonofa.... I get .21v and falling by the second. .197v.... .196v. Argh. So what would be the repair cost on shipping this puppy back and getting a new cap? That would make it the 6th (3rd if your counting it round-trip) time this little puppy's been over the Atlantic... and i've only been over it twice! I think my empeg fell ill to just about every fault there was. But it's still'a'playin'.
|| loren.cox ||
#42734 - 23/10/2001 14:32
[Re: loren]
It is collecting frequent flier miles...
Seriously, extremely bad luck... Dragi "Bonzi" Raos
Zagreb, Croatia
Dragi "Bonzi" Raos
Q#5196
MkII #080000376, 18GB green
MkIIa #040103247, 60GB blue
#42735 - 23/10/2001 14:35
[Re: bonzi]
argh, i guess i'll just email support about it. I don't REALLY need the clock i guess... so maybe i'll just live with it until i get some dying urge to have a working clock.
Hugo... is there any reason it would be a bad idea to leave the dying cap in there? Is it used for anything else?
|| loren.cox ||
#42736 - 23/10/2001 16:10
[Re: loren]
No, it's just connected to the RTC. Leaving it in there shouldn't cause any problems.
#42737 - 26/10/2001 00:07
[Re: loren]
Loc: California, USA
I just upgraded my player to 2.00 beta 3 and tried to set the clock from the player's menu. It updated the clock, but I saw exactly what was described above.
#42738 - 02/12/2001 20:34
[Re: altman]
Loc: Campbell, CA
Mine is having the same problem after recently installing 2.0b3 and attempting to use the clock for the first time. It doesn't remember the time settings after being turned off (either completely removed from power or in-car with accessory power off). I'm assuming this is not the correct behavior.
How long should it take the RTC cap to charge to its full 3.5v? Does it only charge when the unit is on? Or should it also charge in the car with everything off?
- Eric
#42739 - 02/12/2001 20:43
[Re: Drakoz]
The fact that the info-screen clocks do not properly update, but the visual clock does, is a known bug that is fixed in the next release of the software.
#42740 - 03/12/2001 02:35
[Re: esb]
The RTC will charge when in-car and the unit is in full shutdown (or anytime it's on/standby); it takes maybe 30-60 minutes to fully charge up. It should hit something like 3.2v peak; anything below 2v and the supercap isn't working right.
#42741 - 03/12/2001 09:09
[Re: altman]
Does that mean that if every single minute the empeg is in my car, I have it ON and playing music, that the RTC will never charge? Does it charge with the 12vdc mains connector at home?
#42742 - 04/12/2001 08:10
[Re: hybrid8]
No, I said it'll charge anytime basically, INCLUDING when it is in-car and totally "off". The charging current is miniscule.
#42743 - 05/12/2001 01:26
[Re: altman]
Loc: Campbell, CA
Hugo -
Thanks for the help. After checking mine, the cap seems to be fine . Its just a touch under 3.5v. Unfortunately the system won't retain the time and date during a complete system shutdown (either with or without power). Is there anything else I should check before contacting support? I'd like to avoid parting with the unit if possible. Although I did just get an iPod, so I suppose I would survive ;-).
#42744 - 05/12/2001 16:39
[Re: esb]
Very strange; can you send me a boot log ( [email protected])?
The RTC is connected to some GPIO pins on the audio sampler chip. If this is not working (has been heard of before) then the RTC won't work.
