#4296 - 08/06/1999 14:24 Display colours
Martin
Loc: Livingston
Can we see some pics of the empeg players with the alternative (amber & green) displays. my car has an amber lit dash and i will probably order my empeg in that colour if it blends in :-}
Dweeby :-)
Dweeby :-)
#4297 - 08/06/1999 16:07 Re: Display colours [Re: Martin]
We'll have some more pics up soon: the amber is pretty cool.
Green is much like VT100 terminal screen green: I've attached a pic (I can't find our amber bezel - we don't have the production ones here). The other thing in the pic is the car docking sleeve, which is the bit which you fit permanently in your car.
Mmm. Attachment doesn't appear to be working...
http://www.cryton.demon.co.uk/temp/DCP00370.JPG
#4298 - 08/06/1999 20:16 Re: Display colours [Re: altman]
CHiP
It appears that the "glass" or plastic that covers the display is all that makes it a color. If that's the case, Could we get 2 colors. Green would match my car, but i like blue much better. I can't decide. (maybe we can't switch them)
-CHiP
#4299 - 09/06/1999 00:57 Re: Display colours [Re: CHiP]
While it's just the front panel which decides the colour, there are some high voltages on the display board (60v DC) - which is why we don't really want users to play with the fronts. It may happen at some point, though.
#4300 - 09/06/1999 21:41 Re: Display colours [Re: altman]
CHiP
Hugo,
So that means that I could send the unit back to get the display changed when i get a new car? Basically, you would just change the plastic in the front? What color is the display without the cover? White?
-CHiP
#4301 - 10/06/1999 01:21 Re: Display colours [Re: CHiP]
It's sort of whitish-greenish - standard VFD colour. You *do* need a filter though, as the contrast isn't great standalone.
Yes, a service center could switch fronts for you. If you're out of warranty I'm sure you could manage it yourself, it's only 4 screws...
#4302 - 10/06/1999 13:01 Re: Display colours [Re: altman]
thoffman
What about Red? I've got a car with red gauges, and that would be perfect...
#4303 - 11/06/1999 01:40 Re: Display colours [Re: Martin]
tecnodude
Does anyone have any information on how the display looks in sunlight?
I'm having a problem reading the display on my current radio system when its in direct sunlight.
-Jim
#4304 - 11/06/1999 07:56 Re: Display colours [Re: tecnodude]
It's not perfect, I have to admit: sunlight is something *very* hard to deal with in display technology. Direct sunlight is basically impossible to combat.
However, the rest of the time the display is just bloody impressive. Especially with 3D cubes bouncing to the music. Oh yes. :)
#4305 - 11/06/1999 10:26 Re: Display colours [Re: altman]
Nils
Loc: Germany
Hi !
Again the question for you is:
Which display color looks best under sunlight conditions ?
( Iwould think green, but please hugo, whats your experience ?? )
Thank you: Nils
#4306 - 11/06/1999 10:31 Re: Display colours [Re: altman]
Nils
Loc: Germany
Oops, one more remark !
Direct sunlight IS beatable.
My current Car System ( Clarion ) is well readable under *extreme* sunlight,
because then the display looks inverted ->
The numbers/letters then appear darker then the background.
But of course the backdrop is -> the display is not readable under medium light conditions, because then background and numbers/letters are the same brightness.
But -> a nice try from clarion ( if this was intended ).
Nils
#4307 - 12/06/1999 21:35 Re: Display colours [Re: thoffman]
espencer
Loc: Florida, USA
If the display colours are set with the front plate, then it would be easy enough to get platic coloured film (like they use for stage lighting) and attach it to a custom cut piece of plexiglass. My brother used a similar technique in his car to change an Alpine unit to red.
#4308 - 15/06/1999 21:59 Re: Display colours [Re: altman]
mander
Is it possible to order 2 different colors? Is this a user changable item?
Thanks,
#4309 - 16/06/1999 19:55 Re: Display colours [Re: mander]
CHiP
That's a great idea! I think the colored plastic is only attached with 4 screws in the front.
-CHiP
-CHiP
#4310 - 12/07/1999 23:00 Re: Display colours [Re: thoffman]
lumpy
Loc: USA
Yes easily!
I have a display in my pontiac that is the amber VF display, I added a red gel to it to give it "redder" tones easily.
All ya gotta do is first void that pesky warranty first!
(I expect my unit to be voided exactly 3 months after it is installed. :-)
remove NOSPAM to send me email
