#43012 - 20/10/2001 15:06 cut and paste in new emplode
silvercas
what happened to it? if I go to properties on my file I cant cut and paste the names anymore!
#43013 - 21/10/2001 13:52 Re: cut and paste in new emplode [Re: silvercas]
Oooh. I'll see if I can find out what broke. For now, use drag-and-drop instead.
#43014 - 21/10/2001 14:06 Re: cut and paste in new emplode [Re: Roger]
bonzi
A *very* minor related UI wish: could fields in properties window be select-on-enty (so that when I, for example, mass add track numbers using Alt-3 I don't have to delete or select 0 already there).
Dragi "Bonzi" Raos
Zagreb, Croatia
#43015 - 21/10/2001 14:08 Re: cut and paste in new emplode [Re: bonzi]
Can do.
#43016 - 21/10/2001 14:37 Re: cut and paste in new emplode [Re: Roger]
Henno
Loc: Meije, Netherlands
Can do.
While in this agreeable mood, could you add a button that commits the current edit, opens up the next track/playlist, *and* selects the same field the cursor is in as in the track/list just edited? Would be *very* nice . . .
Henno
mk2 6 nr 6
#43017 - 21/10/2001 16:53 Re: cut and paste in new emplode [Re: Henno]
In that mode, I can probably get it to select the same field as last time (i.e. when you press OK). That good enough?
#43018 - 22/10/2001 04:05 Re: cut and paste in new emplode [Re: silvercas]
Resolved: WORKSFORME.
Unless you've got some more information about how to reproduce this behaviour?
#43019 - 22/10/2001 05:47 Re: cut and paste in new emplode [Re: Roger]
silvercas
ok if I drag a file from my c: drive to the emplode then opposite click it and choose proporties the cut and paste option isnt available ( via a opposite click )
#43020 - 22/10/2001 06:01 Re: cut and paste in new emplode [Re: silvercas]
Ah. I see. The options aren't on the popup menu in the edit box. More precisely, there's no popup menu. That's odd.
Use Ctrl+X,C,V for the time-being. They _do_ work.
#43021 - 22/10/2001 06:08 Re: cut and paste in new emplode [Re: Roger]
silvercas
yup... sorry I wasnt that clear.. i thought it was clear and to the point :)
