#43109 - 21/10/2001 15:00 Duration / AudioCatalyst
Henno
Loc: Meije, Netherlands
The new emplode shows that my Mk2 has *many* tracks with a blank 'Duration' field. I tried to replace the tracks with newly encoded ones, but the field stays blank.
Is this caused by the AudioCatalyst / WinAmp clash? What should I do to get proper values in this field. Tried editing, but emplode doesn't allow this (yet )
Henno
mk2 6 nr 6
#43110 - 21/10/2001 15:26 Re: Duration / AudioCatalyst [Re: Henno]
In the FAQ section at RioCar.org there is a link to a piece of software that will repair a song's VBR headers if they are damaged.
I do not know if that is your specific problem or not, but if VBR headers are the problem, that will filx it.
#43111 - 21/10/2001 23:37 Re: Duration / AudioCatalyst [Re: Henno]
It's a Realjukebox/Audiocatalyst clash. RJ installs a later version of the Xing compressor (Real bought Xing) which doesn't generate VBR indexes.
#43112 - 23/10/2001 08:56 Re: Duration / AudioCatalyst [Re: tfabris]
Henno
Hi Tony - quick as usual eh?
You're referring to MP3TagStudio, are you not?
I've used it to repair the VBR headers with success/ But now that emplode shows such info, it appears that there is also damage to the 'duration' field; it is set to blank. I'll try to re-install and old AudioCatalyst version.
Henno
mk2 6 nr 6
#43113 - 23/10/2001 09:01 Re: Duration / AudioCatalyst [Re: altman]
Henno
later version of the Xing compressor (...) doesn't generate VBR indexes.l
Hugo / Roger
Any chance you'll allow us to edit the duration field from emplode?
(so I won't have to re-rip almost 200 tracks?)
Henno
mk2 6 nr 6
