#43520 - 23/10/2001 18:44 2.0 beta 3
SpeedBump
i'm having a problem i can not sync, I found that I have a mp3 with 0 bites, that I can't delete, so I was going to try to go back to 1.03 and I can not downgrade the firmware. it reboots the unit and then goes back to the play menu when I try and up/downgrade the firmware.
#43521 - 23/10/2001 22:14 Re: 2.0 beta 3 [Re: SpeedBump]
You can force it to take 1.03 if you unplug the power from the player, then apply power to the player when the upgrader screen asks you to do so.
#43522 - 24/10/2001 15:11 Re: 2.0 beta 3 [Re: tfabris]
SpeedBump
i got it to down grade and i deleted the file and then re flashed it with 2.0beta 3 and so far so good.
