#43571 - 24/10/2001 05:02 How do you set the clock ?
GADGETBOY1
Loc: SCOTLAND
I have just installed the new software and like the clock display , but I cant figure out how to set up the clock to show the right time . Can anyone help ?
#43572 - 24/10/2001 06:16 Re: How do you set the clock ? [Re: GADGETBOY1]
muzza
menu - settings - time
RTIM
Murray
new styleee
#43573 - 24/10/2001 08:45 Re: How do you set the clock ? [Re: muzza]
Gareth
Loc: Peterborough, UK
Can the RDS time from the tuner module update the system time?
#43574 - 24/10/2001 09:19 Re: How do you set the clock ? [Re: Gareth]
I hope not. The RDS clocks at various radio stations in my area are waaay off. Basically I think these stations just buy an RDS transmitter, plug it in, input their call letters and some slogan, and never touch it again.
-Tony
MkII #554
#43575 - 24/10/2001 10:16 Re: How do you set the clock ? [Re: Gareth]
tms13
Loc: Lochcarron and Edinburgh
Not at the moment. But there was talk of doing so (at the user's request, with the clock visible so you know that the RDS is right - not that I've ever seen the BBC get it wrong, but...).
Toby Speight - 040103385
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
#43576 - 24/10/2001 10:34 Re: How do you set the clock ? [Re: muzza]
GADGETBOY1
Loc: SCOTLAND
I have checked my main menu and don't have an option for settings . Do I need to install a differeent kernel to be able to adjust the clock . Sorry if I appear stupid.
#43577 - 24/10/2001 10:39 Re: How do you set the clock ? [Re: GADGETBOY1]
He means the main menu on the player screen. Note that if you have a Mk1 player, it does not have a realtime clock, only the Mk2 and Mk2a players have a realtime clock.
What version of the software have you installed on the player?
#43578 - 24/10/2001 10:42 Re: How do you set the clock ? [Re: tfabris]
GADGETBOY1
Loc: SCOTLAND
It is a mark 1 . So I take it I have just got to use the clock on the Radio to get the time . It was one of the first Mark 1 serial no 263.
#43579 - 24/10/2001 10:50 Re: How do you set the clock ? [Re: GADGETBOY1]
Heh, that's actually pretty late in the Mk1 production run.
#43580 - 24/10/2001 12:04 Re: How do you set the clock ? [Re: tms13]
cwillenbrock
Loc: Dover, NJ
Speaking of which...wasn't there discussion of synching the time on the empeg with the time on your PC when using Emplode? I think I remember hearing that. That'd rule.
- Chris
32GB MK2 090000664 Smoke
Queue # 2 (who the heck was 1?)
- Chris Orig. Empeg Queue position 2
#43581 - 24/10/2001 13:54 Re: How do you set the clock ? [Re: tfabris]
schofiel
Yeah, that 'un were a right young 'un, it were.
#43582 - 24/10/2001 15:12 Re: How do you set the clock ? [Re: tms13]
Gareth
OK, how about an option to only sync with the RDS source if it is within 1 minute (or so) of the systems current time?
That would stop setting the wrong time from stations which give incorrect RDS time data (not that I've seen any do so)
Is the current date available from within the RDS data?
#43583 - 24/10/2001 23:44 Re: How do you set the clock ? [Re: tfabris]
muzza
Sorry. As you were new to the board, I assumed you had a Mk2
My Bad.
Murray
dust me selecta
#43584 - 25/10/2001 00:44 Re: How do you set the clock ? [Re: muzza]
Right, there are a few issues here:
1. Mark 1's have no RTC (realtime clock). Therefore, there's no menu option to set them. There shouldn't really be any way to display the clock on a mark 1, because it's almost certainly bogus.
2. Setting the clock from RDS. Should work on a mk1. Is the tuner on a mk1 good enough to pick up RDS reliably? However, since some stations don't broadcast the correct time, this needs to be configurable. You can't use any magic, like is it <1 hour out from the current time -- mk1's don't have the RTC. Great for the mk2, though.
3. Setting the clock from emplode. Same as #2, but the time won't be wrong. Still won't work on the mk1, though.
#43585 - 25/10/2001 05:49 Re: How do you set the clock ? [Re: Roger]
Derek
Loc: NRW, Germany
Here in Germany the Mk1 tuner has no problem picking up the RDS clock, and reasonably reliably. Well where I'm living anyway. Am I correct in thinking that once it has synchronised the clock over RDS it keeps running by itself? Still keeps running in my underground parking garage anyway, and the radio signal there is pretty weak!!
