I noticed in the 2.0b3 release notes something about time zones working. As it's coming up to the end of BST here, I thought I'd ask about this.
Does it mean that you can specify a TZ value for the player process, and it will use UTC for the RTC in the kernel and the player will use the correct offset for display (with DST if required)?
If so, where do we specify it? In config.ini? And are the permitted values the same as on my desktop Linux box?
Or is it just about applying the time zone offset specified in the received RDS stream?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
