#44095 - 29/10/2001 05:25 Emplode Software
GADGETBOY1
Loc: SCOTLAND
I am having problems with Emplode running on Win 2K .It keeps reporting that it cannot find the player .I have resorted to loading from a Win98 machine also wheni upload music the files are uploaded but do not appear under the playlists from the player play list menu , but if you use the remote and use the search function for groups the files are found. Is it me or something else
It is a mark 1 using the consumer image version 2 beta 3
#44096 - 29/10/2001 06:57 Re: Emplode Software [Re: GADGETBOY1]
It should work fine under Windows 2000. Mine does.
Do you have any Little Yellow Boo Boo icons in the Windows Device manager with the player plugged in?
Also, it might be worth a try to downgrade to 1.03 and see if it solves your problem (if so, report it in the Bug Reports forum).
You must create playlists within emplode before they will appear in the playlists menu.
In a future release of the software, you will be able to play the "unattached" songs from the player's main menu, without needing playlists.
#44097 - 29/10/2001 11:03 Mine Works [Re: GADGETBOY1]
avatarTX
Loc: Dallas Texas USA
I had one little problem at first but it was easily overcome. When I installed the upgrade from win98 to win2000 my system did not recognize the USB port. I had it search for new hardware, it found it and everything has been working peachy keen ever since.
Carl Aydelotte Dallas Texas USA empeg MKII 080000506 40gb-green
#44098 - 29/10/2001 11:05 Re: Mine Works [Re: avatarTX]
Yeah, good point. Gadgetboy, do you have any other USB devices which work under Windows 2000? Does the USB controller show up at all in the device manager?
