#44279 - 30/10/2001 14:00 Dimmer problems...
omarkhayyam
Loc: Chicago
Ok...my empeg has been acting screwy for a while, even before I updated to the v2.0 beta. What happens is that sometimes when my (mk II) empeg boots up, the display boots up dimmed (but still visible), and sometimes it boots up normally. There is no correlation between this happening and the headlights being on or off. Also, when I go and check the "dimmer" option in the menu, it's at %100 even when the display boots up dimmed. However, if I press the right arrow button as if I was trying to increase the percentage past %100, the display "undims" and functions normally until the next time I start the car.
BTW, the install is in a 1997 Audi A4.
Any help would be appreciated,
Adam
"It's not that I'm lazy, it's that I just don't care..." -office space
#44280 - 30/10/2001 15:57 Re: Dimmer problems... [Re: omarkhayyam]
edwin
Loc: Druten, The Netherlands
This has happened to me also several times before and after beta upgrade... Don't know what causes it.
[white]ญญ______________[/white]
Edwin de Vaan aka FLaSHmAStER
#44281 - 05/11/2001 03:15 Re: Dimmer problems... [Re: omarkhayyam]
thnielsen
I had that immediately after going to 2.0b3, but setting it to 100% the first two times I started the car, made it go away. Now it allways starts correctly at 100% (AND bright ;-)
(RedMKII 12G in BMW540)
#44282 - 05/11/2001 08:40 Re: Dimmer problems... [Re: omarkhayyam]
ClemsonJeep
Loc: Ashburn, VA
This is a known problem, and has been for a long, long time. It was "supposed" to be fixed in 2.0 though. :)
(O|||||O)
