#44986 - 04/11/2001 00:28 Search field criteria
muzza
What are the units of some of the search criteria?
specifically, what unit does duration use?
#44987 - 04/11/2001 01:27 Re: Search field criteria [Re: muzza]
I put that one in the FAQ a couple of days ago. Jeez, don't you people ever check?
Note: The entry in the FAQ contains data from the time around a very old 1.1 alpha. It might not be fully correct. If anyone can give me more feedback on how accurate that entry is with 2.0b3 I would be grateful.
#44988 - 04/11/2001 03:09 Re: Search field criteria [Re: tfabris]
bonzi
I could not find answer to Murray's question in the FAQ. Anyway, duration seems to be in milliseconds.
#44989 - 04/11/2001 10:13 Re: Search field criteria [Re: bonzi]
Near the bottom of the "player operation" section. The heading refers to the advanced search box. Duration is in there.
#44990 - 04/11/2001 10:26 Re: Search field criteria [Re: tfabris]
bonzi
You are right again. I saw duration mentioned, but not (a few lines above) the part on time units. For duration the default unit (if none is given) is milliseconds, but now I know one could also use more 'normal' ones.
BTW, I now took some time to browse through the FAQ again. You really managed to improve on already excellent BBS version. Invaluable resource, indeed!
#44991 - 04/11/2001 10:40 Re: Search field criteria [Re: bonzi]
Thanks. :-)
I'll see if I can improve that one bit.
#44992 - 04/11/2001 13:56 Re: Search field criteria [Re: tfabris]
muzza
Sorry Tony, I didn't look hard enough!
i'm off to self administer a dope slap
#44993 - 04/11/2001 16:04 Re: Search field criteria [Re: muzza]
There's so much information in the FAQ now that I'm not sure the simple Q&A format is sufficient to find the information you need. I wonder if it would be possible to add search features to the software, to make it into more of a knowledgebase..
#44994 - 04/11/2001 20:17 Re: Search field criteria [Re: rob]
Drakino is aware that a search feature is sorely needed for the whole site (not just the FAQ).
Let's hope he's got some of that Copious Spare Time (tm)...
