#4586 - 29/09/1999 09:29 Developing on FreeBSD
brianosaurus
My box at home runs FreeBSD rather than Linux. I have the Linux emulation libraries installed, so I was able to download the arm-linux toolchain package from www.empeg.mars.org and successfully build a few of the examples on that site, and run them on my empeg.
Next thing I want to try is getting PPP running over my wireless modem (Ricochet in the SF Bay area). There is a package on the mars.org site, but it is in some Debian package format that I don't know how to unpack (there's a gzip'd tarball in there somewhere, I just know it ;). Little help here?
I guess going further, assuming I get the package installed on my empeg, does it *NEED* a debian environment to run, or would it work in the standard config using the ppp kernel on the empeg.org site?
brian
#4587 - 30/09/1999 07:51 Re: Developing on FreeBSD [Re: brianosaurus]
Verement
Loc: Boston, MA, US
You can convert the Debian package into a generic .tar.gz by using alien.
I considered putting a tarball on the web site, but the pppd binary has been linked against the libcrypt shared library which I would also need to distribute, and I'm uncertain about possible (albeit ridiculous) U.S. export restrictions on this library.
As far as I know, as long as you have the necessary shared libraries, only the pppd binary is needed to run PPP using the PPP kernel - a Debian environment should not be required.
#4588 - 30/09/1999 12:43 Re: Developing on FreeBSD [Re: brianosaurus]
n6mod
Loc: Berkeley, CA
Keep us posted on this, and feel free to ask if you need help with the modem itself. I've never run ppp on linux, but I was in Metricom's tech support group for two years. ;)
-Zandr
-Zandr
Mk.IIa #010101243 currently getting a 500GB SSD. More spares in the shed.
#4589 - 30/09/1999 15:03 Re: Developing on FreeBSD [Re: brianosaurus]
mac
Loc: Cambridge, UK
Debian packages are ar(1) archives - you can extract a standard .tar.gz from them with
ar x wibble.deb data.tar.gz
HTH
Mike Crowe
I may not be speaking on behalf of empeg above :-)
Mike Crowe
