#4620 - 23/10/1999 06:59 Compiling apps inside empeg
kim
Loc: Helsinki, Finland
Has any empeg owner tried to compile any software inside empeg yet?
Is 8MB memory enough for GCC to run? Including all necessary libraries, etc.
I'm planning to develop/debug software under Win32 and then just compile the same source code inside empeg, using compiler directives to separate platform dependent code (such as display/keyboard/remote controller handling).
Does anyone have any experience on this?
#4621 - 23/10/1999 10:32 Re: Compiling apps inside empeg [Re: kim]
Verement
Loc: Boston, MA, US
I can confirm that it is possible to run gcc on the empeg itself, but you will probably need to add some swap space as the available memory is very low.
