#4874 - 17/08/1999 09:34
My empeg
Hypnotised (a brief review of empeg) ===================================
I cannot remember having anticipated the arrival of anything at my house so much since I was a child waiting for Christmas; well, Christmas came a bit early (last Wednesday, to be precise) and yes, for once it's as wonderful as I imagined.
Out of the Box ============== empeg is delivered in a small, white box, and my first thought was "where's the rest of it?" Opening it up revealed a neat, delightful piece of compact packing and a surprising amount of stuff shoved in there. The unit is packed inside the sled, and around and under the unit is a CD with the software, a neat little A5 booklet of general instructions, serial and USB cables, a power supply, and - wonder of wonders - the correct power cable. This may seem a trivial point, but having unpacked numerous systems delivered by major hardware manufacturers only to find I have to walk to the hardware store for the correct plugs, I was not expecting this - a nice bit of attention to detail.
So around 30 seconds after I had the box open ("it took you THAT LONG??"), empeg was plugged in and booting... more of that later.
First Impressions =================
empeg is an incredibly tidy, compact little unit, hefty (but just "so") and beautifully made - empeg Ltd. have not done this by halves. This is no amateur construction; professional labelling, quality brushed stainless steel case finish, protection layer to the front panel, gold plated connectors, CNC'd handle - it all points to professionalism and quality.
But dammit, that luvverly handle - as beautifully machined as it is - is still a dull gunmetal finish, and ouch! it doesn't open far enough out to get your fingers through it easily. The consequence of this is that when you pull the unit out and walk with it, it hangs awkwardly and is somewhat difficult to hold without fear of dropping it. A minor modification to the handle metalwork should cure this one quickly; and it would be *really* nice if the securing screws for the front panel and the handle itself were anodised to the same colour as the facia perspex....
The facia is a coloured perspex plate, secured by countersunk screws recessed into the plate itself; to the left hand end of the plate there's a neatly sized and placed group of four control buttons, with a a clean, controlled operation. You can just sit there for ages pressing them, listening for that "click"....
The sled is a folded and TIG-welded stainless affair, made of remarkably thick sheet - more so than I would have expected and definitely a notch up on the sled metalwork provided by the likes of Philips and Blaupunkt. An enormous bundle of cable stubs (including a serial cable) poke out of the back, and a choke is supplied separately for a healthy installation in the guts of your dashboard; all the accompanying cables are good quality too, including the afore-mentioned power cable.
Finally, there's the Kenwood Remote control, which is not custom designed for the empeg, but definitely suited to this application; neat and small, it's credit card sized and sports an array of feature buttons formed as domed bubbles; good button press feedback means you don't have to worry about whether the button was actually pressed or not. All in all, a genuinely pleasing article with a delightful tactile feel (in more than one sense!).
Plugged In ==========
The unit runs as soon as you can get it to you nearest power socket; after displaying the empeg logo with the Penguin, it boots *really* rapidly (around six seconds) and spits up a small group of text messges as the various software components start up. In fact, it's almost too quick; given most computer users' experiences of boot latency, you almost get a shock at the speed with which it comes up. For a second I was left there wondering if it was busted, or hung up!
If anything, it's *too* quick; the logo is only on the screen for about a second, and it would be nice to have it stay up there for a bit longer, or until you operate it for the first time; that would be a real street-cred point winner over geeks in the know, travelling in the back... There's a sample track supplied on the disk; the first thing I did was press "Play" on the remote and cracked the mask with a grin that would have left lipstick on my earlobes (had I been wearing any, you understand! ;^)
Pictures ========
Now comes what is arguably, aside from sound quality, the best bit of empeg - the display graphics. Centered in the deep blue of that facia appears a dancing, hypnotic display of light that has to be seen to be believed (OK, the hyperbole may take over a bit here). You can step through a choice of what seems to be a huge collection of alternative visualisations of your music, with variations on a theme; dancing bees, oscilloscope, "flame" spectrum analyser, bounce box, spinning bass cube, fast conventional spectrum analyser, slow-decay spectrum analyser, mirror spectrum, symmetric spectrum, 2-axis Lissajous, negative 2AL, diffraction grid, negative DG, and a few others I can't call to mind. Wonderful, dancing, hypnotic - in fact, one of the things I've noticed about these displays is this hypnotic, calming effect they seem to have on the people watching them ("I'm sorry Officer, I just didn't notice the approaching contraflow system, as I was watching the spectrum analyser on my empeg at the time...").
They have to be seen to be believed, as I cannot do them justice in print. Since they are the most visible part of the system, I suspect they may well be the first things that after-market add-ons target, adding more and more displays to chose from - screen saver package, anyone? One minor grumble here is that *once*, and only once, did the empeg logo pop up (to my surprise) while stepping through the displays; a bug, or an Easter egg, empeg Ltd.? ;^) Now all you need is to have a spinning penguin...
Sound Quality =============
As you'd expect, it's strikingly good (even to my jaded ears). As always, this is going to depend on the quality of your MP3s (it goes without saying that GIGO will definitely apply here). The supplied test track played back with excellent clarity through my stereo at home; curiously enough, for the first time, I seem to have found an input source that can properly drive the pre-amp, which resulted in (for me) quite superb sound clarity.
Why go into depth? Much like the graphics, you have to hear it to believe it, and since much sound appreciation is in the end subjective, I will leave it to experts to review the merits of playback. It has *not* disappointed me, however, in fact exceeding my expectations. Having only been able to compare this against a Diamond Rio (with different music tracks), my impression is - better definition, with improved high frequency playback than the Rio. I want to try comparing this against the CDs I ripped for it through the same audio equipment, and against a DAT source also.
Software ========
The software supplied with the unit is the emplode download and playlist management software required to put music in your box; it is still Beta, and this is noticeable. This does *not* however mean "unusable" - that's not the case. It is sufficiently noteworthy to become annoying on occasions, however. Additionally, there are a few odd problems with the the empeg unit software itself, which empeg Ltd. acknowledges.
Is this so bad? Given the clamouring expectation for the product, I feel that it has been a well-justified decision to release the unit with software at this stage of development. There are rough edges, true, but given the quite exceptional time-to-market for what is a revolutionary, and complex, piece of gear, then empeg have only to be congratulated for the monumental achievement this represents.
Problems? One or two small display bugs, a playlist hierarchy problem, and (at the moment) somewhat limited features - but this can only improve as the software is enhanced and developed, so I for one await the next release with great anticipation.
That's the bad news out of the way - the good news is, the menu structure and operation is just *sooo goood*, especially the sideways-scrolling action of the menus. The menus are available through both keypad and remote; fading, balance, volume, loudness, playlists, power, AUX selection and visualisation are all controlled by the feature menu. With the menus off, play control and source selection can all be rapidly carried out, including changing to the radio and back, selecting presets, turning track info on and off, stepping to the next visual - all with a single keypress. What's missing, however, is the ability to step to the next playlist with one press, and an audio feedback cue to let you know the remote keypresses are getting through to the unit without having to look at the display while you are driving (a la Philips, Alpine, Sony, etc.). No doubt this will be addressed at a later date.
(As a side note, I have found that I can bounce the remote off the back kitchen window, across a 5m room, off a mirror and still control the unit!)
So, to sum up the software - "close, but no cigar!" (yet ;^)
Conclusions ===========
So what's my overall impression? In spite of the fact that I am utterly besotted by the thing and am being rather less than totally objective, in the end it is very hard not to be impressed by empeg. Small things such as the packaging, build quality, heft, the little touches in the menus and software, and (of course) the sound and graphics make this one "pretty awsome consumer experience".
So - hang in there! Yours is coming (soonish)!!
#4875 - 17/08/1999 14:11
Re: My empeg
[Re: schofiel]
Why doesn't someone who has already recieved their Empeg by kind to the masses and snap a few pics of their unit, then put them up on a site for others to view. All of us with >1000 reg. numbers would greatly appreciate it. I know there are pictures on the Empeg site but they are only updated once in a blue moon. How about pics of the visualization modes, navigation features, etc, anyone with a digital camera and an Empeg?
#4876 - 17/08/1999 15:07
Re: My empeg
[Re: jwilliams]
If I'm honest, the pictures on the web site are pretty accurate; I went back to have another look tonight before I posted my review. If anything, they give the impression that the unit is actually quite *large*,so imagine you are looking at the real thing close-up!
I really wish I had a digital camera for you guys; unforch, I spent it all on the empeg.... ;^)
I will try and borrow something from my mate to see if I can come up with some pictures for you; in the mean time, I would be quite happy for anyone in The Netherlands to come and see the thing (given a little warning beforehand, so I can get the beers in, of course!)
Not long before the first "empeg party", methinks......
#4877 - 17/08/1999 15:15
Re: My empeg
[Re: schofiel]
I have just rung my mate Harry who just so happens to have a super-8 video with an S-VHS output. Given that the time is around midnight, he was less than impressed, I must say...
Since I have a Matrox Millenium with a piggy-back board for video capture, there is an *outside chance* I may be able to take a short film of the unit in operation. Goodness knows what the quality will be like, and no idea what the format will be. PaulH, can I post digitised videos? I know the limit is 10K attachments, is there any chance of a once-off exception to the rule if I can do this?
#4878 - 17/08/1999 18:24
Re: My empeg
[Re: schofiel]
Loc: Texas, US
I can host a movie or two for you on my site if you need it. I will just need to spend a little time with my MacOSX Server to get the Quicktime streaming working first. My unit is on it's way! I will also make a Quicktime or AVI movie available on my site at http://www.BORGcube.com/EMPEG as soon as my unit shows up.
#4879 - 18/08/1999 01:13
Re: My empeg
[Re: schofiel]
Loc: England
It really depends on how large the attachment is - you will probably want to look around for a good codec.
The server the BBS runs on is on a friends line so I don't want to eat up too much of his bandwidth as he uses this line for his business. The BBS itself generates a fair bit of usage as it is, I was pretty impressed to see that the SQL backend broke the 1 million queries mark this morning (having been up for 2 weeks).
If you can't find a site to host this then I'll put it up on another server I have access to and link it to this one.
Hopefully I'll get my empeg today too, shame someone borrowed my digital video camera last nite :-(
#4880 - 18/08/1999 01:49
Re: My empeg
[Re: PaulH]
Hi there Paul,
I appreciate your concern about the usage - I neglected to think of that. Sorry for being a bit inconsiderate!
Having said that, it probably won't be necessary anyway - it looks as if Chris has actually posted a short video on his home page, so I won't need to for the moment.
What I think I'm going to do is borrow a digital camera and do the same (stick it on my homepage), then post the URL when it's up there.
#4881 - 18/08/1999 05:15
Re: My empeg
[Re: jwilliams]
Loc: Manchester, UK
There is talk of us posting a few video clips of the visualisation modes on the official website. The plan is to write some code to grab these direct from the video frame buffer via serial and convert them to some known format.
However we are all very busy at the moment with other bits of code, and also thought that perhaps it would be more exciting for people to wait for their units to turn up than already have seen its features on arrival.
Toby (Prolux Real Time Visuals)
#4882 - 18/08/1999 15:06
Re: My empeg
[Re: schofiel]
Loc: Switzerland
if you need space for your video/pics etc.. you can send it to me and i'll put it on my site... space is no problem..you can have 100 meg if you need.. msg if u need some webspace..
l8r
KoS
