#49974 - 14/12/2001 08:26 DHCP Issues
nester
Loc: Louisville, KY, USA
Hi,
Got my new player. Love it, only one issue using the 1.0X and the 2.00-beta3 release. While DHCP works at home with no problem, I can not get it to work at work.
The differences between home and word are the following:
* Work uses ISC DHCPd, Home is the Cisco 678 DSL Router
* Work uses real ip's, while I'm on NAT at home
* Work DHCP server is on a diffrent subnet on a different segment of network. We're using Cisco's dhcp-helper (i believe) to get the requests and ack's to and from..
This setup works for all of the Windows, Mac, and Linux boxen on the network but the Empeg just hates me. Once I set the IP manually with the serial cable, it works great.
We've checked the DHCP server logs, and the request is getting there, but either the lease is not getting back to the player or the player is ignoring it.
I tried searching on this, but DHCP tends to bring tons of posts with boot messages.. and I even checked the faq.. woo.
#49975 - 14/12/2001 09:29 Re: DHCP Issues [Re: nester]
Dearing
Loc: Florida
What does the log look like on the empeg? DHCP send/Recieve messages get sent out the serial port like the boot messages.
_~= Dearing =~_
#49976 - 14/12/2001 10:01 Re: DHCP Issues [Re: Dearing]
nester
Vcb: 0x408ce000 DISK drive
3c1b1ed2 DHCP Sending DHCP discover (eth0)-210, ATA DISK drive
3c1b1ed2 DHCP Extensions present: 61 53 55 57
hda: IBM-DJS
E !! mp3_decoder.cpp 1052: Failed to seek to offset 311596, error=0xc0044000 on irq 6
hda: IBM-DJSA-210, 9590MB w/384kB C
E !! mp3_decoder.cpp 1047: Failed to find valid sync after seeking to offsetpeg-flash driver initialized
smc chip id/revision
smc9194.c:v0.1
3c1b1ed3 DHCP Sending DHCP discover (eth0)
3c1b1ed5 DHCP Extensions present: 61 53 55 57into ram disk... done.
3c1b1ed6 DHCP Sending DHCP discover (eth0)ounted root (ext2 filesystem).
3c1b1ed6 DHCP Extensions present: 61 53 55 5780601)
Press Ctrl-
3c1b1ed7 DHCP Sending DHCP discover (eth0)1
3c1b1ed7 DHCP Extensions present: 61 53 55 57okay
Freei
3c1b1ed8 DHCP Sending DHCP discover (eth0)is a developer image!
3c1b1ed8 DHCP Extensions present: 61 53 55 57
Mounting proc
Mounting first
3c1b1ed8 DHCP Testing Auton
Remounting second
3c1b1edb DHCP Sending DHCP discover (eth0)
No secondary ha
3c1b1edb DHCP Extensions present: 61 53 55 57 go into development mode. You Have Zero Seco
3c1b1edc DHCP Sending DHCP discover (eth0)
3c1b1edc DHCP Extensions present: 61 53 55 57eta3 2001/10/17.
3c1b1edd DHCP Sending DHCP discover (eth0)
3c19c6aa DHCP index = 1
3c1b1edd DHCP Extensions present: 61 53 55 57
3c19c6aa DHCP addr = 0.0.0
3c1b1ede DHCP Sending DHCP discover (eth0)CP bcast = 0.0.0.0
3c1b1ede DHCP Extensions prese.0
3c19c6aa DHCP Our mac is 00:02:d7
3c1b1ee1 DHCP Extensions present: 61 53 55 57
3c19c6aa DHCP Current IP address is 0.0
3c1b1ee2 DHCP Sending DHCP discover (eth0)
3c19c6aa DHCP Broadcast address is 0.
3c1b1ee2 DHCP Extensions present: 61 53 55 57
3c19c6aa DHCP Attempting to open Autonet so
3c1b1ee3 DHCP Sending DHCP discover (eth0)
3c19c6aa DHCP A
3c1b1ee3 DHCP Extensions present: 61 53 55 57
3c19c6aa DHCP Sending DHCP discover
3c1b1ee4 DHCP Sending DHCP discover (eth0)
3c19c6aa DHCP Extensions present: 6
3c1b1ee9 DHCP Sending DHCP discover (eth0)
3c1b1ee9 DHCP Extensions present: 61 53 55 57
3c1b1eea DHCP Sending DHCP discover (eth0)
3c1b1eea DHCP Extensions present: 61 53 55 57
3c1b1eeb DHCP Sending DHCP discover (eth0)
3c1b1eeb DHCP Extensions present: 61 53 55 57
3c1b1eec DHCP Sending DHCP discover (eth0)
3c1b1eec DHCP Extensions present: 61 53 55 57
3c1b1eed DHCP Sending DHCP discover (eth0)
3c1b1eed DHCP Extensions present: 61 53 55 57
3c1b1eee DHCP Autonet IP address 169.254.170.56 (eth0)
3c1b1eee DHCP Autonet netmask 255.255.0.0 (eth0)
3c1b1eee DHCP Autonet inferred broadcast address 169.254.255.255 (eth0)
etc etc etc
#49977 - 14/12/2001 13:51 Re: DHCP Issues [Re: nester]
Hmm, don't know why you're having that trouble, but you can work around it by setting the player to a fixed IP address that falls within the desired DHCP range...
#49978 - 14/12/2001 22:04 Re: DHCP Issues [Re: tfabris]
nester
Rather defeats the purpose of having DHCP at all..
Esp if I have to reconfigure the player each time I'm at home and then when I go to work.
*sigh*
if i could bind two ip's.. that'd be cool. eth0 , eth0:1...
#49979 - 14/12/2001 23:37 Re: DHCP Issues [Re: nester]
Right, I was merely suggesting a work-around until the issue could be resolved.
There is a description of how to handle this in the FAQ.
#49980 - 15/12/2001 09:19 Re: DHCP Issues [Re: nester]
nester
Also, for what it's worth, that paste from Hyperterminal is mangled, but you get the idea. I'm not sure why the buffer of HT got like that.. but go figure, I'm sure it's the exact same version that came with 95, now in XP. :)
