#51302 - 24/12/2001 17:43 Mark I - No Joy
xavyer
Hardware: Empeg Mark I (single drive)
Software: car1-developer-v2.00-beta7.upgrade
Problem (repeat ad-nauseum):
Starting player
player.cpp : 550:empeg-car 2.00-beta7 (internal) 2001/12/22.
Prolux 4 empeg car - 2.1326 Dec 22 2001
Vcb: 0x402bd000
player(123): memory violation at pc=0x0208e0e0, lr=0x0208e0d8 (bad address=0x00000008, code 2)
pc : [<0208e0e0>] lr : [<0208e0d8>]
sp : be3ffbcc ip : be3ffbcc fp : be3ffc2c
r10: 0215c200 r9 : 0215c274 r8 : 0219b9f0
r7 : be3ffbd8 r6 : 0215c200 r5 : 00000000 r4 : 0000007f
r3 : 00000000 r2 : 00000010 r1 : 00000003 r0 : 021a7858
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C014517D Table: C014517D DAC: 00000015
Function entered at [<0208dc18>] from [<0208d8c4>]
r10 = 0219B9F0 r9 = 0215C274 r8 = 0213D3A4 r7 = 02178A10
r6 = 0215C34C r5 = 02178A00 r4 = 0000000C
Function entered at [<0208d504>] from [<020d64a0>]
r10 = 020D6428 r9 = 0219B9F0 r8 = 00002C0C r7 = 00000080
r6 = 0000000C r5 = 0219B9F0 r4 = 0217457C
Function entered at [<020d6428>] from [<020ddd04>]
r5 = 0219BA08 r4 = BE3FFE40
Function entered at [<020ddc3c>] from [<021160dc>]
r4 = 00000000
Function entered at [<021148d0>] from [<020dda80>]
r8 = 02177564 r7 = 02177550 r6 = 020D6428 r5 = 00000003
r4 = 00000001
Function entered at [<020dd9d0>] from [<021160dc>]
r5 = 00000000 r4 = 00000000
Function entered at [] from []
Function entered at [] from [<00000181>]
Restored terminal settings
No secondary hard disk
Abnormal player termination
Player received signal 11
#51303 - 25/12/2001 05:42 Re: Mark I - No Joy [Re: xavyer]
Interesing.. has anyone else tried Beta7 on a Mk.1? Have you tried the consumer version?
I loaded the consumer version onto a Mk.1 on Friday and it worked fine.
#51304 - 25/12/2001 08:39 Re: Mark I - No Joy [Re: rob]
mtempsch
Currently pumping partion ... [insert muzak] ...
Done! 2.0b7 developer seems to work fine for me. (Dual drive)
#51305 - 25/12/2001 12:31 Re: Mark I - No Joy [Re: rob]
xavyer
Hardware: Mark I (single drive)
Software: car1-consumer-v2.00-beta7.upgrade
The consumer upgrade seems to boot just fine; though, I wonder if anyone else has seen this sort of error on a single drive Mark I using the beta7 developer image.
Happy Holidays.
#51306 - 26/12/2001 04:46 Re: Mark I - No Joy [Re: rob]
TommyE
Loc: NORWAY
I have tried both, consumer/developer. They both install and run fine for playing music.
My problem is that when syncing, and I get to the point 'restarting player' the empeg hangs forever. I've tried looking at the shell with the serial cable to see what it does. All I can see is that it remounts the drive just before it hangs.
/me also thinks maybe it can be a memory problem, but who knows.
TommyE
#51307 - 29/12/2001 16:17 Re: Mark I - No Joy [Re: TommyE]
bonzi
Isn't this known problem with 2.0betas? I just ignore them when they happen with my MkII (emplode either fails to restart the player or the player gets quite suttery and unstable after restart). I just reboot the player and exit emplode...
