#5310 - 14/11/1999 09:00 Audi A3/S3 Install + Bose System
philb
I am considering buying an Audi S3, and I was wondering if anyone has any opinions on a couple of things:
1. The factory fit head unit is wider than DIN, I understand that an adaptor is available to fit standard sized units, how does this work with the empeg docking cage?
2. Audi have an uprated Bose speaker system, including sub that fits around one of the rear wheel arches. This looks like a very neat solution, but is it compatible with the empeg? I can't find any technical details on Audi's webpage and the Bose one is just full of the usual waffle. Alternatively would the 450quid be better spent at cambscaraudio? :-)
Phil.
#5311 - 15/11/1999 04:56 Re: Audi A3/S3 Install + Bose System [Re: philb]
schofiel
By chance I had a ride this w/e in our neighbour's new A3 (is that the same as an S3?)which does have the enhanced Bose system they offer installed as an option. I have to confess I was rather impressed by the sound quality; if nothing else the speakers are impressive. I honestly don't know if the head unit has a built-in amp or if it is seperate, so I can't comment on how you would add an empeg to the system - but I certainly would look at buying the option installed and retaining the speaker system.
#5312 - 15/11/1999 12:52 Re: Audi A3/S3 Install + Bose System [Re: schofiel]
Cambscar
Loc: Cambridge, UK
The adaptor plates for the A3 actually screw in either side of the dash aperture (or at least the Autoleads ones we sell do anyway), and should work OK with the Empeg cage. The only slight problem you might encounter is that the Empeg cage tends to be just a little bit under standard DIN size (probably only by 1 or 2mm), and you may find it's a bit loose in the dash. If so, it ought to be simple enough to remedy with a thin plastic or similar shim.
All the Bose systems in A3s that I've seen have used the head unit's inbuilt amp to run the front speakers, and the slightly odd level pre-amp output from the unit to drive an active amp in the rear. We sell an adaptor lead for these (again, it's an Autoleads part) that allows you to run a 2v+ pre-amp output into the original amps. This ought to work fine with the Empeg's higher than average pre-out voltage, so all you'd need to add is a small amp to drive the front end.
The Bose systems do tend to sound pretty good - we'd be hard pushed to offer an equally good system for the same price, and it wouldn't integrate quite as neatly into the vehicle. It pains me to have to admit that, but manufacturers in general (and Audi in particular) have actually got their act together a bit better of late.
Dominic
Cambridge Car Audio
http://www.cambscaraudio.co.uk
