#5331 - 19/11/1999 22:00 Alternator blues
dionysus
Loc: San Francisco, CA
OK guys, I've tried to follow every advise on here regarding alternator noise, but it's still really bad; and the more I play with it the worst it seems to get:( noise goes up and down w/ volume control, I might add, which leads me to believe it might be the + power wire... does anyone have any more suggestions on this? I might add that my old head unit had almost no alternator whine...
-mark
#5332 - 21/11/1999 01:42 Re: Alternator blues [Re: dionysus]
Ser Olmy
Loc: London, England
What car? And what sort of noise? Is it a whining that goes up and down in frequency in relation to engine rpm?
Regards
Simon
Awaiting delivery... #5833
ser# 348
#5333 - 21/11/1999 21:56 Re: Alternator blues [Re: Ser Olmy]
dionysus
Hi,
This is in a '99 honda accord... The noise gets louder when the engine is going faster - also I've noticed that turning on the AC doubles the noise (...I guess because the alternator has to work harder?)
It's actually not too bad w/ the AC off, but it's almost unbearable with the ac running...
-mark
#5334 - 25/11/1999 08:47 Re: Alternator blues (...and how it was fixed) [Re: dionysus]
dionysus
ok - here's what I ended up having to do in my car (...I can barely hear the alternator noise now w/ the player paused..)
seperate ground wire - ended up running another cable from the amp's ground, to the negative on the headunit.. also hooked up this same ground to the rca leads provided (only on the headunit..) - shielded this ground from reaching the amp using a groundlook isolator..
ALSO had to hook up this negative at the headunit to the CHASIS near the headunit.. (why??? this got rid of 90% of the noise, and the ground-loop isolator got rid of the other 10%)
I'm not even sure why it worked, but it's playing beautifully now w/o hardly any alternator whine
