#5398 - 06/02/2000 05:50 Unit mounting angle
bonzi
Hi!
Let me reiterate my previous question: Is it OK to install the Empeg at angle other than horizontal? Somebody here said that disk shock mounts are supposed to work with the unit mounted horizontally, and some disk manufacturer's data sheets prescribe either vertical or horizontal mounting.
The matter is that in my Twingo I can only mount the unit off-vertically, at some 70 degrees. Is that a problem?
Thanks!
Dragi "Bonzi" Raos
Zagreb, Croatia
#5196
#5399 - 06/02/2000 05:51 Re: Unit mounting angle [Re: bonzi]
The shock mounts are designed for horizontal mounting only - sorry :(
The citroen CX has the same problem, I think.
#5400 - 06/02/2000 06:29 Re: Unit mounting angle [Re: altman]
bonzi
Dominic, HEEEELP! How do I mount Empeg in my '97 Twingo?
(Hugo, what do you do WORKING on Sunday afternoon ? Then again, I am writting this from one window, while some credit cars management stuff I am working on is compiling in other...)
Dragi "Bonzi" Raos
Zagreb, Croatia
#5196
