#55680 - 06/01/2002 17:49 Hard Drive (theoretical limit)
kojak71
Ever increasing densities have seen in the desktop market the upper limit capacity of 137Gb reached and breached (Maxtor bundle their 160Gb beast with a specially commissioned Promise controller to get around this problem). So does the eMpeg have a theoretical limit as well? If so, what is it?
#55681 - 06/01/2002 17:53 Re: Hard Drive (theoretical limit) [Re: kojak71]
Terminator
Loc: Dallas, TX
Yes, do a search on the board and you'll find it. I cant remember off the top of my head.
#55682 - 06/01/2002 18:05 Re: Hard Drive (theoretical limit) [Re: Terminator]
Peter said the empeg will probably run into the limit here
If anyone personally owns enough CDs to fill a 256 GB empeg, they can afford two in their dash
#55683 - 06/01/2002 18:08 Re: Hard Drive (theoretical limit) [Re: drakino]
kojak71
Thanks, so it seems to be similar to IDE in desktops as well.
#55684 - 06/01/2002 18:11 Re: Hard Drive (theoretical limit) [Re: kojak71]
Yes, IDE between laptop drives and desktop drives is the same. The problem was in the amount of bits set aside to address a drive. At 128gb, the address limit is hit. Maxtor helped to fix this by making the address bit width wider in Ultra 133 controllers and drives.
I thought I heard something about linux possibly able to workaround this limitation if the controller dosen't do it on it's own, but I may be mistaken. If so, the empeg may be able to break that limit.
#55685 - 06/01/2002 18:41 Re: Hard Drive (theoretical limit) [Re: drakino]
It *was* mentioned in the other thread that an update to 2.4 of whatever linux installation pieces would bring support (possibly) for drives larger than 128MB (137). That's 48bit instead of 28 I believe. Bruno Posting from the Macworld tradeshow floor - nearly finished setup (man this place is freezing!)
#55686 - 06/01/2002 21:26 Re: tradeshow report [Re: hybrid8]
muzza
You do realise that we want updates and details of all the cool stuff?
