#55997 - 07/01/2002 08:14 Eclipse Spyder Install
dmob
Loc: Boston
Has anyone installed their empeg in an Eclipse Spyder? If so, how did it go? Anything I should know about the install before I begin? I want to install my empeg underneath my Alpine deck, hopefully everything will fit without a problem. Any advice would be helpful!
#55998 - 07/01/2002 09:06 Re: Eclipse Spyder Install [Re: dmob]
Scorp1us
I'll be doing this shortly, but it's not a spyder.
Are you indending to put it in the hole between the head unit and heating controls too?
#55999 - 07/01/2002 09:09 Re: Eclipse Spyder Install [Re: Scorp1us]
JoshMKiV
2G DiamondStars have double DIN holes, so should be no problem at all. Just take it with you, too easy to steal it from a drop top.
#56000 - 07/01/2002 10:47 Re: Eclipse Spyder Install [Re: Scorp1us]
dmob
Loc: Boston
My Spyder is a 97 so I am not sure if the newer models are set up differently (or what year you have) but I have my head unit in that spot already. I am planning on putting it under the head unit. Might be a little tricky getting it in and out of that spot though...
#56001 - 07/01/2002 12:02 Re: Eclipse Spyder Install [Re: dmob]
eternalsun
Loc: San Jose, CA
I have a Spyder Installation. The thing you should know about is there is not a lot of room at the back so the cables/wiring and stuff will need to be carefully folded up as the cage will "crush" it against the back The next thing is you need a double din adapter if you wish to make it fit right with the alpine deck. The alpine deck will have a trim ring around it that will need to be cut.
I know this because *I* have an Alpine deck happily coexisting with the empeg. It feeds into the aux-in on the empeg.
But if I had to do it again, I would take the alpine deck out entirely because it is not worth the trouble. I never use the alpine deck and it just looks bad next to the classier looking empeg.
Calvin
#56002 - 07/01/2002 12:03 Re: Eclipse Spyder Install [Re: eternalsun]
eternalsun
Loc: San Jose, CA
I'll post up installation photos at some point.
Busy.
Calvin
#56003 - 07/01/2002 14:19 Re: Eclipse Spyder Install [Re: eternalsun]
dmob
Loc: Boston
Photos of your install would be great. Thanks in advance.
#56004 - 07/01/2002 14:30 Re: Eclipse Spyder Install [Re: dmob]
wvloon
Loc: Near Arnhem, Netherlands
I wonder if Tony fell asleep ? Normally he'd point out that this sort of questions actually belong in the Installation notes section. It must be very hard for him to keep up with the enourmous amount of new messages from new happy (soon to be) owners.
[email protected] ------------------------ Reg:1934/Mk1:158-Blue(sold)/Mk2:380-Amber(sold)/Mk2a:3273-Blue
#56005 - 08/01/2002 11:38 Re: Eclipse Spyder Install [Re: dmob]
eternalsun
Loc: San Jose, CA
I'll definitely take some photos, I'm considering doing Tony's magic marker mod. I have a Darkstorm smoked kit and a wood faceplate coming in. I'm mostly waiting until everything is together before I snap pictures. :-)
Calvin
#56006 - 08/01/2002 13:36 Re: Eclipse Spyder Install [Re: eternalsun]
For the record, it's not my mod. I think it was originally suggested by Mike and implemented first by Henno. Details here.
