#5708 - 11/05/2000 11:32 redhat linux usb kerel 2.2.15 howto
dave
Loc: San Diego, CA
After downloading 2.2.15 and applying the USB patch to my redhat 6.0 machine i was unable to compile the usb module for the empeg.
I sent an email to John Ripley (the author) and got this QUICK response:
Change the line (line 52) from:
#include "usb.h"
to:
#include
That fixed it! THANK YOU JOHN!! I now get 221K a second transfers!! (KICK ASS) or 1 cd every 5 minutes :)
#5709 - 12/05/2000 03:19 Re: redhat linux usb kerel 2.2.15 howto [Re: dave]
john
If you want (maybe) faster USB, change the number on the line:
#define EMPEG_CAR_NPACKETS 32
to 1024. Really this shouldn't do anything to speed and just wastes a bit of memory, but in practice it gives about 10-20% faster transfers. Something not quite right in the (PC) USB stacks.
- John (from empeg)
(The above may not represent the views of empeg :)
#5710 - 12/05/2000 21:36 Re: redhat linux usb kerel 2.2.15 howto [Re: john]
danthep
Loc: new zealand
Where is this patch for USB on 2.2.x?
I heard suse had something, but decided 2.4 was gonna be here anyday now so didn;t investigate. Now it looks like it might be a little longer than first envisaged
#5711 - 16/05/2000 14:22 Re: redhat linux usb kerel 2.2.15 howto [Re: danthep]
dave
Loc: San Diego, CA
You can get it at:
http://www.suse.cz/development/usb-backport/
a good "usb" page is http://www.linux-usb.org/
Havn't tried uping the buffers yet, actually i havn't had time to pull the unit out of my car! :)
#5712 - 17/05/2000 13:30 Re: redhat linux usb kerel 2.2.15 howto [Re: john]
dave
Loc: San Diego, CA
I tried uping it to 1024 and got this. I will mess around some more with diffrent values...
BTW it worked when i switched it back to 32, and normally i use the --usb option with emptool.
was trying to "keep it simple" :)
[root@dave empeg-car]# emptool --debug 3 /dev/empeg-car
2000 Checking connection [ 0% mpeg-pump v0.03 (19980601)\x0d
2000 Checking connection [Done
2121 Downloading
2121 Starting download [Done
2122 Retrieving tags index [Done
2123 Retrieving databases [ 0% imeout in state 3 (substate=7567)
!LOCAL_DROPOUT!timeout in state 3 (substate=7567)
!LOCAL_DROPOUT!
4010 Failed to receive database, result -2101
#5713 - 17/05/2000 14:00 Re: redhat linux usb kerel 2.2.15 howto [Re: john]
dave
Loc: San Diego, CA
I was able to up EMPEG_CAR_NPACKETS to 64 (from 32) this resulted in 241K a second transfers!
up 20K a second! ! Now if i could only get the same gain going to 1024!!! :)
