#57868 - 11/01/2002 07:12 Stuttering after pause
Captain_Chaos
Loc: Amersfoort, The Netherlands
After having been paused a long time, the player has trouble resuming play. The sound will often (but not always) stutter a few times before continuing.
/Pepijn
#57869 - 11/01/2002 09:50 Re: Stuttering after pause [Re: Captain_Chaos]
beaker
Loc: England
Mine would stutter several times after pausing with 2.0b3. It still stutters with 2.0b7 but it only does it once while it's waiting for the drives to spin up.
#57870 - 11/01/2002 10:26 Re: Stuttering after pause [Re: beaker]
Captain_Chaos
Yes, I also have the impression that beta 7 stutters less than beta 3. But since the audio information is still cached in the RAM, it should be able to resume playing without stuttering at all...
/Pepijn
#57871 - 11/01/2002 11:32 Re: Stuttering after pause [Re: Captain_Chaos]
The Guys are closing in on what they think the stability problems are. Some discussion among the alpha team suggests that this problem (along with many others) might be solved in the next relase.
A temporary stop-gap measure might be to set reservecache to 8 in config.ini. That was something Mike had us alpha testers try to see if it solved any problems. I know it solved one (unrelated) problem I was having related to synchs, but I don't know if it will fix this one for you.
#57872 - 11/01/2002 13:06 Re: Stuttering after pause [Re: tfabris]
beaker
Loc: England
Thanks Tony, I'll try that.
#57873 - 11/01/2002 16:07 Re: Stuttering after pause [Re: tfabris]
beaker
Loc: England
OK, tried that and the stutter has gone (well so far anyway) .
