#58903 - 14/01/2002 19:39 problem with new Rio Car: i2c failure
kday
Loc: Boston, MA
I sent this to [email protected]; just to cover all the bases I'll put it here as well.
Hello --
I just unpacked my new unit and discovered it won't synchronize with Emplode. This is what appears on the serial console at boot time:
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux.................................... done, booting the kerne.
Linux version 2.2.14-rmk5-np17-empeg41 ([email protected]) (gcc vers1
empeg-car player (hardware revision 9, serial number 40104128)
Command line: mem=16m temp=32
Memory: 15048k/16M available (972k code, 20k reserved, 336k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Logo type is 1
empeg display initialised.
empeg dspaudio driver initialized
empeg infra-red support initialised.
empeg state support initialised 0089/88c1 (save to d0004300).
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:0
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initempeg-car 1.02.
000003f6 DHCP Our mac is 00:02:d7:28:10:20
000003f6 DHCP Our address is 255.255.255.255
000003f6 DHCP Broadcast address is 255.255.255.255
000003f6 DHCP Current IP address is 255.255.255.255
000003f6 DHCP Sending DHCP discover
i2c: Failed to receive ACK for data!
i2c_write: write second byte failed, count:38
i2c_write: address select failed
000003f7 DHCP Sending DHCP discover
000003fa DHCP Sending DHCP discover
#58904 - 14/01/2002 21:26 Re: problem with new Rio Car: i2c failure [Re: kday]
Terminator
Loc: Dallas, TX
#58905 - 14/01/2002 21:34 Re: problem with new Rio Car: i2c failure [Re: Terminator]
SE_Sport_Driver
#58906 - 14/01/2002 22:10 Re: problem with new Rio Car: i2c failure [Re: SE_Sport_Driver]
Terminator
Loc: Dallas, TX
Support is read by david, this will be responded to quickly. Since it appears to be a hardware problem sending it to David would be a good idea. I don't know how the bugs addy is handled, but theres a chance he would never get a response from it.
So no, they don't necessarily go to the same people. ;-)
