Well since I got my empeg a couple of months ago I've always wanted to build a docking sled. Which indirectly has to use the pre-outs on the sled.
So what I've done to test this, is connect 1 empeg to each source on my stereo, set them to 0db (Why would I have anything else inside). And played the same song on each. I then switched the inputs on my stereo between the 2 to compare.
And all I have to say is, the quality is much better (Maybe just cause the volume is louder, but I don't think so). The empeg which was connected using the 1V home pre-outs sounded muddy at the same volume.
Now all this was tested using a Aiwa mini-theater system which has JBL pro studio speakers connected to it, I have yet to try it on my NAD component system.
What started this journey was the output of my SBLive connected to the same jacks was much louder then the empeg.
In the other thread I mentioned people were saying the output of the empeg didn’t sound as good as other components, now if you can use the docking sled with the 4V pre-outs and it doesn’t cause distortion I can’t see a problem. Now one thing I didn’t test yet, maybe they’ll be more static using 4V pre-outs
Ben
Rio Car 10GB + 60GB Toshiba ([green]Green[/green]) - Serial # 30102833
